Author Topic: pulleys  (Read 2979 times)
Offline twister428
pulleys
« on: January 23, 2015, 04:30:37 PM »
I have a box of pulleys and am trying to remember which are for my 70 R code?  Non a/c, non ps, with pb. Any help would be appreciated.
Re: pulleys
« Reply #1 on: January 23, 2015, 07:19:09 PM »
The crank pulley I believe should be C8AE-6312-D, and the water pump I think is still a 3 sheave pulley even without P/S? Ink stamped, no obvious casting stamp. You would have to check diameters to identify.
priceless
  • Guest
Re: pulleys
« Reply #2 on: January 23, 2015, 08:34:21 PM »
The water pump pulley is a 3 groove pulley with a C8AE-8509-C before 9/1/69. And a C8OE-8509-A after 9/1/69 with an outer diameter of 7 7/64" on both and an inner diameter of 6 17/64" on both.
Offline rayms69
Re: pulleys
« Reply #3 on: January 24, 2015, 12:38:53 AM »
10-26-1969 Dearborn 428 SCJ auto
priceless
  • Guest
Re: pulleys
« Reply #4 on: January 24, 2015, 05:01:00 PM »
interesting reading on the 428 forum. I noticed under the "water pump pulley notes" that our own Brian Conway found between the two sheaves C6TE-8509-C. That pulley, from the mustangtek website, is for a 68 289, 302 Fairlane and Falcon and also 69-70 390 Ford. I'm assuming that 2 pulleys were grafted together to form the C8OE-8509-A ??
Re: pulleys
« Reply #5 on: January 25, 2015, 12:08:03 AM »
Those kind of pulleys are the ones that are typically ink stamped for identification.
Offline Mike_B_SVT
Re: pulleys
« Reply #6 on: January 25, 2015, 01:52:18 PM »
The C8OE - A pulley is a smidge smaller than the C8AE-C.
C8OE-A = 2 sheaves at 6", 1 sheave at 5 and 3/64"
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
Offline sportyworty
Re: pulleys
« Reply #7 on: January 25, 2015, 07:34:35 PM »
Mikes dimensions are correct for the Pulley except it is a 3 sheave
C8OE-8509-A   5 3/64" and 6"
C8AE-8509-C    6 17/64" and 7 7/64"
Lots of errors on Mustang Tek
