Author Topic: Horn jumper wire harness  (Read 2092 times)
Offline kcodecoupe
« on: January 22, 2015, 03:44:00 PM »
On 1970 428 & boss 302 metuchen or dearborn cars with a factory oil cooler what was done with the left side horn wire as it was not used when the horns were located to the right side and the jumper wire was installed, is there a picture to refer to, thanks , chuck.
Re: Horn jumper wire harness
« Reply #1 on: January 22, 2015, 07:07:16 PM »
     I have a couple pictures of that area for my 69 Metuchen car.  Early 69 the abandoned left horn plug was incorporated into the headlight wire loom wrap.  The white dot in the middle of the picture.  Brian
Offline kcodecoupe
« Reply #2 on: January 22, 2015, 07:45:56 PM »
Thank you posting the pics brian,
« Reply #3 on: January 22, 2015, 11:53:09 PM »
69 Boss 302 without the oil cooler used them also.
Jack Brooks/DeadNutsOn sells a reproduction of the short jumper wire on his site
http://www.deadnutson.com/catalog/item/4943784/5042495.htm
Offline kcodecoupe
« Reply #4 on: February 15, 2015, 07:07:17 PM »
are the repo jumper wires the same color code as the originals,
« Reply #5 on: February 15, 2015, 10:20:08 PM »
brian are you sure the lh horn wire isn't behind the oil cooler
« Reply #6 on: February 16, 2015, 01:05:49 PM »
Yes I am sure it is not behind the cooler.  Marcus Anghel has a ' Factoid ' on his web-site dealing with the jumper wire.  Brian
http://www.anghelrestorations.com/
« Last Edit: February 16, 2015, 04:55:07 PM by Brian Conway »
Offline kcodecoupe
« Reply #7 on: February 16, 2015, 07:35:04 PM »
I have seen two different typs of jumper harness, semo has the blue & yellow stripe wires ,others are one blue and one white wire, what other versions are out there.
