Author Topic: Guide to Original 1965 to 1973 Snubber Brackets  (Read 7888 times)
Offline lightwtjet
9 Inch Axle Pinion Snubber
« Reply #15 on: April 13, 2024, 12:52:10 AM »
I found detailed information on 9 inch axle pinion snubbers done by Anghel Restorations.
https://anghelrestorations.com/wp-content/uploads/2021/09/pinion_snubber_v1.0.pdf
   Our thanks to Anghel restorations for the research done on this. With the various designs that evolved I am wondering if the bracket was getting bent or damaged in use.
   Ford Product Development determined that pinion snubbers were needed when an axle and driveshaft went into full jounce to minimize the sharp jolt (thump) a customer would experience and to prevent the driveshaft from hitting the tunnel and damaging it. On a new car design or an increase in driveshaft diameter we had to do a vehicle test for clearance. To worst case the test we would remove the rubber bumper and put 400 lbs in the trunk and then use the test track to achieve full jounce
« Last Edit: April 26, 2024, 09:57:01 PM by lightwtjet »
1968 CJ - Owner and paint original. Dec 67 build in Dearborn. One of 50 135 Cobra Jets. Ford engineering used it for 8 mos. to resolve problems in the 50 early car build. Ford by-passed the normal sign off to get cars to the Winternationals drag race.
Re: 9 Inch Axle Pinion Snubber
« Reply #16 on: April 13, 2024, 06:13:53 PM »
Yes nice work and thanks for the insight. Hard to believe that almost ten years has passed since it was posted. BTW the article is also posted in the Library section of this site with Marcus' permission  ;)
Offline Anghelrestorations
    • Anghel Restorations
Re: Guide to Original 1965 to 1973 Snubber Brackets
« Reply #17 on: April 13, 2024, 06:35:46 PM »
I feel old all of a sudden..... :-\
Marcus Anghel
www.anghelrestorations.com
« Reply #18 on: April 14, 2024, 12:47:02 PM »
So here's a question actually two about my 69 9"; I have a pinion snubber in the floor not on the pinion and I don't know how to read the ' i ' with two dots below.  Little help ? Brian
The two dots signify the second decade of production. Ford did not use the "I" because they did not want anyone to confuse it with a "1" which means that part was cast in 1971.
