Author Topic: Guide to Original 1965 to 1973 Snubber Brackets  (Read 7887 times)
Offline Anghelrestorations
    • Anghel Restorations
« on: January 22, 2015, 12:20:46 PM »
Put together a new guide on the different style snubber brackets to help identify what is correct for the different years.  Keep seeing these listed wrong on Ebay by different sellers so hopefully this will help those who are looking.
http://www.anghelrestorations.com/uploads/3/1/7/6/3176630/pinion_snubber_v1.0.pdf
Marcus Anghel
Offline PerkinsRestoration
Re: Guide to Original 1965 to 1973 Snubber Brackets
« Reply #1 on: January 22, 2015, 01:12:39 PM »
 Nice work!
Offline mtinkham
  • That'll be easy
« Reply #2 on: January 22, 2015, 01:21:54 PM »
Excellent.
I always understood these to be natural or bare steel.  But, I recently read in an older post on this site that the snubber bracket was phosphate and oil.  Which is correct?
Mark
« Reply #3 on: January 22, 2015, 01:30:22 PM »
great work there!! now if we could get someone to do a battery i.d. guide........
Offline blackjadeboss
« Reply #4 on: January 22, 2015, 01:48:52 PM »
Nice snubbers! Great information once again Marcus.
« Reply #5 on: January 22, 2015, 02:55:25 PM »
Excellent.
Mark
Bare steel originally
« Reply #6 on: January 22, 2015, 04:15:46 PM »
Marcus you may want to amend the text on the version #3.  That style was not only used "up to" but it was used into 68 production when it changed over sometime after the first of the year 68 to the last style.
« Reply #7 on: January 22, 2015, 04:19:45 PM »
Another well done article .   :)
« Reply #8 on: January 22, 2015, 04:27:27 PM »
Sounds good Bob.  I actually had it referenced to change about Feb 1968 but didnt want to pin down such an exact date without hearing from others.  I can change the wording around a bit to indicate that time period.
Marcus Anghel
« Reply #9 on: January 22, 2015, 04:32:13 PM »
Marcus, I used "the first of the year" which would include Feb 68 for wiggle room because I am not sure of a exact definitive date ether . I know that they were changed by April just not sure how much before.
« Reply #10 on: January 22, 2015, 07:58:40 PM »
So here's a question actually two about my 69 9"; I have a pinion snubber in the floor not on the pinion and I don't know how to read the ' i ' with two dots below.  Little help ? Brian
« Last Edit: January 22, 2015, 08:18:59 PM by Brian Conway »
« Reply #11 on: January 22, 2015, 08:46:15 PM »
You have the correct 9 inch bracket in the floor but at some time in the past a PO has bolted the 8 inch? snubber where none should be. 9 inch rear Mustangs had the snubber incorporated into the shield.
Offline sgl66
« Reply #12 on: January 22, 2015, 09:04:20 PM »
Well done Marcus.
My Oct 65 car has the early style shown used on 65 and carry over 66 cars however has the rubber snubber bolted to the plate welded to the chassis. Took a few close ups last year when starting a clean up.
Searched for images on Google and found a picture of a similar style snubber over on VMF. http://forums.vintage-mustang.com/vintage-mustang-forum/625566-how-can-i-tell-if-real-gt.html
Any idea why the difference? A Metuchen thing? Never heard of it being a factory GT thing. I've seen them before on other cars also but don't remember the details
« Reply #13 on: January 22, 2015, 11:45:57 PM »
Nice work again Marcus - Will add a link in the Library for it
.......... I don't know how to read the ' i ' with two dots below.  Little help ? Brian
Seen that decoded (and has matched up on parts for me) as being 1971 suggesting as does the other features that some one in the past has assembled various pieces to make a third member installed in your car
Never heard of it being a factory GT thing......
Isn't - nor a K code thing
« Last Edit: January 22, 2015, 11:49:01 PM by J_Speegle »
Offline 70 Yellow B2
« Reply #14 on: January 23, 2015, 12:25:10 AM »
Thanks again Marcus for another great guide.  I have learned allot and have used them quite a bit to identify parts and understand the differences in parts.
Tim
1970 BOSS 302 - Yellow on White
0F02G150833
