Author Topic: What size hole for clutch rod? and deluxe door wires  (Read 1379 times)
Offline droptopboss
« on: January 17, 2015, 03:30:13 PM »
Title kinda says it all.
 I'm converting my 70 convertible to a 5 speed and I need to know how big of a hole to cut. I'm also adding deluxe interior and need to know hole size there too. Thanks
Re: What size hole for clutch rod? and deluxe door wires
« Reply #1 on: January 17, 2015, 03:32:21 PM »
is there not a knockout hole already present for that??
« Reply #2 on: January 17, 2015, 03:42:15 PM »
If you are doing an automatic to T-5 manual transmission conversion, you should consider a cable or hydraulic clutch.
I used a stock Mustang 5.0 cable, and clutch quadrant conversion from Mustang Steve. All the rest of the parts are 5.0 Fox Mustang, i.e. bell housing and clutch. Flywheel I sourced from Kajun to use with my stock 1968 J code 302-4V.
Offline droptopboss
« Reply #3 on: January 17, 2015, 03:49:01 PM »
No knock out hole but there is a dimple for location.
I'll be using a hydraulic clutch. I had one in my mach 1 for years. I bought a cable kit for it first and it was such a POS I sent it back as fast as I could.
« Reply #4 on: January 17, 2015, 04:32:11 PM »
Whoa Nellie! The firewall hole depends on the size required of the mounting seal you intend to use, and I assume you will use some type of seal. The same applies to the grommets for the door and frame wire. Measure those first then determine what size holes you need.
« Reply #5 on: January 17, 2015, 04:40:11 PM »
     Jim makes a good point.  The door grommets on my 69, deluxe lights, are almost 3" wide out to out.  Might want  to locate the grommets first ?  Brian
Offline droptopboss
« Reply #6 on: January 17, 2015, 05:02:52 PM »
I have the grommets. I know the holes are big for deluxe lights. I have an old mach 1 door I can measure. As far as the hole for the clutch a new oem style / repop grommet will work fine. It did last time anyway. That car was already a 4 speed so I didn't have to cut the hole.
