Author Topic: HIPO connecting rods?  (Read 1242 times)
Offline wunderwerks
« on: January 12, 2015, 02:57:55 PM »
A friend of mine just purchased a large parts collection from an estate and included is a block with a VIN # stamped on the side of the block plus it has the HIPO main caps.  Other than that it is a bare block. In other parts is a set of connecting rods.  Other than the bolts holding on the rod caps, what is the difference between a standard connecting rod and a HIPO rod?  I assume the bolt hole is larger but are there any other differences?
64.5 Cpe. Poppy Red 5F07D 23G
64.5 Conv. Bright Cherry Sparkle 5F08F 16F
65 2 + 2 Caspian Blue 5F09K  23K
Re: HIPO connecting rods?
« Reply #1 on: January 12, 2015, 04:58:03 PM »
Casting numbers are the same, C3AE-D. They are machined different than the standard to accept the 3/8 bolts. This results in a different inventory part number.
Offline wunderwerks
« Reply #2 on: January 12, 2015, 06:26:06 PM »
With consideration of the balancing is there any reason that you would not bore out the bolt holes on standard connecting rods and caps to accept the 3/8s bolts?  Are they physically identical in size (except for the holes) to a standard rod?
« Reply #3 on: January 12, 2015, 07:42:27 PM »
Yes, you're right on the main body of the rod, but the rod end caps are unique to a hi-po.
