Author Topic: 67 390 belt routing - pulley ID  (Read 6550 times)
Offline travnemi
  • Travis Waters
Re: 67 390 belt routing - pulley ID
« Reply #15 on: July 15, 2015, 01:59:45 PM »
Thank you so much!!!! Looks like a hard part to find. If anyone finds one, please let me know.
Travis
Travis Waters
Mine -
1967 Mustang GTA S Code, Fastback, San Jose, Built Dec. 13, 1966 (Thermactor)
Daddy / Daughter Project -
1967 Mustang S Code, Fastback, San Jose, Built Sept. 9, 1966
Offline WT8095
  • Dave Z.
« Reply #16 on: July 15, 2015, 02:13:31 PM »
Travis
There's at least one on ebay right now:
http://www.ebay.com/itm/1966-1967-390GT-Fairlane-Mustang-Power-Steering-Pump-Pulley-without-A-C-AG-/321807713844?hash=item4aed3c0634&vxp=mtr
Not my auction- I can't vouch for the pulley or the seller.
Dave Z.
Offline travnemi
  • Travis Waters
« Reply #17 on: July 15, 2015, 02:19:19 PM »
LOL!!!
I just bought it, Thanks.
I spent hours and hours last night looking for one!!!
Appreciate the help,
Travis
Travis Waters
Mine -
Offline WT8095
  • Dave Z.
« Reply #18 on: July 15, 2015, 03:47:37 PM »
LOL!!!
Travis
Glad to help! I'm in the process of procuring parts for a '68 S-code and figuring out all the same details you're working on now. Seeing your progress is helpful inspiration!
Dave Z.
Offline rodster
« Reply #19 on: July 16, 2015, 12:24:27 PM »
Per the MPC, you need an "AG", C5AZ-G.
Update: added photo (from mustangtek.com).
I'm seeing a 5 inch "AC" pulley on my car.  Could you see if that's listed in the MPC?
67 390, non-GT, no ac, no TE, single alt pulley
Dearborn car build Feb 67.
Thanks.
Rod
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
« Reply #20 on: July 16, 2015, 07:20:18 PM »
Looking at a Feb 68 page from the MPC found a PS pulley identified by a stamped AC
4 7/8" dia
Many applications listed but not a single 390 Mustang one
Only Mustang listing is for 65/ 289  without AC after 8/17/64
Part number C5AZ-3A733-C
Its interesting that the 68 MPC does not show a replacement carried by Ford for that specific application - a 5" pulley is listed as stamped with a 7AA
Lets try to show both references - this might show how confusing and possibly unreliable these sources are for finding the original parts for your car - particularly due to the fact that they only list parts carried in stock (possibly replacing the original parts)  and mistakes in the information continue in each
Feb 68 MPC page
C5AZ-3A733-C (Part number) - Marked AC - Application - Mustang 65/ 289 wo/AC from 8/17/64
C5AZ-3A733-F (Part number) - Marked AF - Application - Mustang 67 390 w/AC
C5AZ-3A733-G (Part number) - Marked AG - Application - Mustang 67 390 wo/AC w/Thermactor
C7AZ-3A733-A (Part number) - Marked 7AA - Application - Mustang 65 & 66 289 w/AC from 8/17/64 & Mustang 67 289 wo/dual alternator pulley before 9/12/66
NOTE: The AC marked pulley description shows other 390 applications for that pulley just not noted as for Mustang. Big Ford and Fairlane applications are as follows
67 Big Ford 390 2V wo/AC - Without T/E (Thermactor) dual alternator, super extra cooling or AC
65/ Fairlane and T-Bird 8 cyl. 289, 390) wo/AC
May 75 MPC page
C5AZ-3A733-C (Part number) - Marked AC - Application - Mustang 67 390 wo/AC w/single alternator pulley
C5AZ-3A733-F (Part number) - Marked AF - Application - shown as being dropped and replaced (for service purposes) by C7AZ-3A733-A listed below
C5AZ-3A733-G (Part number) - Marked AG - Application - Mustang 67 390 wo/AC w/dual alternator pulley
C7AZ-3A733-A (Part number) - Marked AA - Application - Mustang 67 390 w/AC
Shows how much "fun" using just books can be and demonstrates how you can get multiple different answers directly and on web sites.
« Last Edit: July 16, 2015, 07:22:52 PM by J_Speegle »
Offline preaction
« Reply #21 on: July 16, 2015, 08:31:47 PM »
My 67 390 power steering pump has a AF pulley.
Offline travnemi
  • Travis Waters
« Reply #22 on: July 16, 2015, 10:46:52 PM »
I have some belt questions. I have the Thermactor belt part number thanks to Jeff. I'm needing the altenator and Power Steering belt part Numbers. I have a 1967 dec 1966 build SJ 390 GTA  no A/C  with  Thermactor. System. Here are the belt sizes;
Thermactor Belt -
   P/N: C5TE-8620-L - Size: 36.875"
Alternator Belt -
Power Steering Belt -
Also, would anyone know where I could pick up a MPC for my car?
« Last Edit: July 16, 2015, 11:00:25 PM by travnemi »
Travis Waters
Mine -
Offline preaction
« Reply #23 on: July 16, 2015, 11:02:56 PM »
Travis, I needed all the same belts as you and marti auto works had them with the ford script.
Offline travnemi
  • Travis Waters
« Reply #24 on: July 16, 2015, 11:08:35 PM »
The belts they sent me don't fit (alt., and P/S). I called them, their going to send me the correct sizes. Though, I need to supply them with the P/N's for the belts. The only belts I can find for me car are too big. So I was hoping that someone could help me out.
Travis
Travis Waters
Mine -
Offline rodster
« Reply #25 on: July 16, 2015, 11:34:02 PM »
Thanks for the info Jeff, guess you can't believe everything you read.  ;)
 I better check the pulley diameter again, this time with better lighting.  Could be 4 7/8". What's 1/8" between friends?
Pretty sure the pulley is original to the car.
1984 SVO - 2A
« Reply #26 on: July 17, 2015, 03:12:42 AM »
Keep in mind that a correct size belt would typically put the stop bolt in the middle of the adjustment slot once tightened.
