U-joints are new and the original driveshaft was checked, but no balance issues.
I tried an aluminium shaft with no difference. Engine was rebuilt to oem specs.
I had this vibrations before the rebuilt. Tranny and rear end is original to the car.
Had the tires balanced, tried different shops, no difference. Changed the tires from front to rear, no difference.
The vibes occur only at 70+ and get stronger the faster i go. When in neutral the vibes "fade" away fast. Not immediately, but go away.
Had some sloppy yoke in the tranny extension housing, so i changed the bushing and seal. No change ;(
Ill try a rebuilt third member and see if vibes are gone.
Greets
