Author Topic: 1965 Mustang Brake Pedal Pad  (Read 1660 times)
Offline trudera
« on: January 04, 2015, 07:45:18 PM »
Folks
You have helped me out in the past and I need you assistance again. I have a 65 automatic coupe with disc power brakes. Which brake pedal pad is used? It is a standard interior car.
1. C5ZZ-2454-C  has "Disc Brake" written on it
2. C5ZZ-2457-E has "Power Brake" written on it
3. C5andyZZ-2457-F has nothing wrtten on it
Thanks for your help in advance.
Randy
5F08C686647
5F07C714555
Re: 1965 Mustang Brake Pedal Pad
« Reply #1 on: January 04, 2015, 08:20:27 PM »
Opps - as mentioned head was some where else    :o
No power disc brakes on the Mustang until 67 as a option or part of a option  package
Might want to check what your car has again - might have been modified (non stock)
« Last Edit: January 04, 2015, 08:55:40 PM by J_Speegle »
« Reply #2 on: January 04, 2015, 08:23:36 PM »
Folks
Randy
I don't believe this was a factory option. Ans: none of the above.
Offline trudera
« Reply #3 on: January 04, 2015, 08:49:59 PM »
If it is none of the above then what would it. It is for my Dearborn coupe that is a very late 65 car.
5F08C686647
5F07C714555
« Reply #4 on: January 04, 2015, 08:52:15 PM »
According to the Mustang Recognition Guide, there is a picture on page 49 of the brake pedal saying "Power Brake" on it, with a picture above it of the power brake booster.  My understanding, which could be wrong, is that this was only available on the 6 cylinder cars, as the booster and MC combination would hit the valve covers on the V8.  Power disk brakes were not available until 1967.
Online CharlesTurner
« Reply #5 on: January 04, 2015, 09:16:41 PM »
The later 67+ cars with PDB used a pedal that just had 'DISC BRAKES' on it with the stainless circle trim.  Guess if you want to be consistent with later 'Ford practice', then just go that way.  As others have said, it was not possible to order 65-66 disc brake cars with a power booster setup from the factory.
