Author Topic: 70 Front Disc Brake Caliper Safety Wire  (Read 4469 times)
Offline kcodecoupe
« on: January 02, 2015, 02:22:20 PM »
Did 70  frt disc brake caliper mounting bolts have lock washers or just the safety wire to secure them to the spindle. or both.
« Last Edit: November 27, 2019, 10:42:23 PM by J_Speegle »
Offline Anghelrestorations
    • Anghel Restorations
Re: 70 front disc brake caliper Safety Wire
« Reply #1 on: January 02, 2015, 04:37:57 PM »
For the bolts that hold the caliper mounting bracket to the spindle there both lock washers and the safety wire.  It would be two bolts per spindle.
« Last Edit: November 27, 2019, 10:40:37 PM by J_Speegle »
Marcus Anghel
www.anghelrestorations.com
« Reply #2 on: January 02, 2015, 05:36:45 PM »
I've read that a couple of times, did you mean there are aka there're?
Sorry, English is a first language but does have its quirks.
« Last Edit: November 27, 2019, 10:40:45 PM by J_Speegle »
« Reply #3 on: January 02, 2015, 05:47:06 PM »
Both lock washers and safety wire were used on caliper mount to spindle bolts
Think it was just a typo
« Last Edit: November 27, 2019, 10:40:53 PM by J_Speegle »
« Reply #4 on: January 02, 2015, 05:57:15 PM »
Looking for a clarification. If you can make a mistake and do it wrong, I can make a mistake and do it right - if I knew what you were doing.  ;)
« Last Edit: November 27, 2019, 10:41:03 PM by J_Speegle »
Offline Brian Conway
Re: 70 front disc brake caliper mounting bolts
« Reply #5 on: January 02, 2015, 06:01:26 PM »
FWIW The same lock washer and safety wire are used on my 69.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
« Reply #6 on: January 02, 2015, 07:40:56 PM »
« Last Edit: November 27, 2019, 10:41:12 PM by J_Speegle »
« Reply #7 on: January 02, 2015, 10:19:13 PM »
Yes...sorry.  I have been drinking too much eggnog this holiday season.  There is lock washers and safety wire.  Usually I see the safety wire missing if the car was taken apart in the past.
« Last Edit: November 27, 2019, 10:41:20 PM by J_Speegle »
Marcus Anghel
« Reply #8 on: January 03, 2015, 01:49:47 PM »
I had that situation on a car, the shop didn't have safety wire or the tool available, so they just "did me a favor" and left it off. They are no longer in business. I wonder why?
« Reply #9 on: January 03, 2015, 04:18:48 PM »
Sounds like they did themselves a favor by not putting it back together correct.  I think the safety wire pliers are about $10 - they are not hard to find.  Used alot in the aircraft industry.
« Last Edit: November 27, 2019, 10:41:29 PM by J_Speegle »
Marcus Anghel
Offline rickmustang
« Reply #10 on: November 26, 2019, 04:54:54 PM »
This is an old post and the pics are no longer available. Can someone post how the safety wire is supposed to go on a '70 disc brake car. Also, what is best source for the wire? Thanks.
1970 black R-code 428 4-speed Mach 1
Built in San Jose mid-October 1969
« Reply #11 on: November 26, 2019, 05:07:12 PM »
Don't know that we ever posted pictures to the thread but will see if I have anything. BTW thanks for posting the request here rather than starting a whole new thread :)
On the point of the safety - there may be (very likely) differences between plants and possibly even workers so just be prepared for that and also finding the right size wire and metal can be a challenge at times but there is at least one other thread that offered suggestions I use to buy it locally at Orchard Supply labeled Annealed Wire or Annealed Baling Wire. Almost bought an extra roll when they closed but just didn't need another.
« Last Edit: November 26, 2019, 07:26:37 PM by J_Speegle »
« Reply #12 on: November 26, 2019, 07:20:30 PM »
- what is best source for the wire?
Amazon.
Offline rickmustang
« Reply #13 on: November 27, 2019, 04:03:48 PM »
My car is San Jose build
« Last Edit: November 27, 2019, 10:39:47 PM by J_Speegle »
« Reply #14 on: November 27, 2019, 04:33:14 PM »
Sorry don't have any pictures currently from a 70 San Jose example hopefully someone else will have a picture
« Last Edit: November 27, 2019, 10:39:55 PM by J_Speegle »
