Author Topic: C5GF-12127-A distributor  (Read 1558 times)
Offline rodster
« on: December 30, 2014, 10:01:59 AM »
Not mine but 2 currently listed on ebay.
Thought I'd post since they don't seem to come up very often.
Ebay search on C5GF-12127-A
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline markb0729
  • South Jersey
Re: C5GF-12127-A distributor
« Reply #1 on: December 30, 2014, 03:19:11 PM »
Too bad they are missing complete vacuum advance units.  Complete, rebuildable vacuum advance units are getting hard to find.
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
Offline rodster
« Reply #2 on: December 30, 2014, 05:59:35 PM »
Thanks for that info, I didn't know that.
Luckily the 65 distributor I picked up had the vacuum advance.  ;)
1984 SVO - 2A
« Reply #3 on: December 31, 2014, 12:08:06 AM »
The diaphragm part you want is C5AZ-12370-A, Motorcraft DD-190. Those numbers came off the box. Do not get confused by other numbers, they are incorrect. The best identification of the correct item is that it has a 5/8-18 tapped hole for either the metal tubing vacuum fitting or the later used 3/16 rubber vacuum tube. Yes, they are rare. The current "replacement" has a permanent 3/16 od tube attached where the 5/8-18 tapped hole was.
