Author Topic: 70 San Jose - body sealer  (Read 1556 times)
Offline blackthunder70
« on: December 26, 2014, 06:23:17 PM »
hi guys
restoring a 70 drag pac car
was the sealer in the engine bay and door pillars put on after the the paint or before the paint
thanks
barry
« Last Edit: January 01, 2015, 05:25:50 PM by J_Speegle »
Re: body sealer
« Reply #1 on: December 30, 2014, 02:46:21 PM »
What plant ?
Engine bay sealant -
Are you asking about the firewall pass through  or firewall to inner fender sealant ?  Or the cowl under panel to firewall pinch sealant?
« Last Edit: December 30, 2014, 03:00:47 PM by J_Speegle »
Re: 70 San Jose - body sealer
« Reply #2 on: January 01, 2015, 06:17:33 PM »
Seam sealers located on the A pillars and in the engine bay on a late (June) 70 built San Jose Mustang would have been applied as follows
On the cowl to firewall, A pillar seams and cowl to side cowl panels - these were applied before body color.  as shown below
Black baked off cowl top
A pillar seam - not done on early cars but done on later examples
Sealers on all (well that was the plan) of screws, master cylinder to booster to firewall, hoses and electrical pass-through items would have been applied after the black engine compartment paint
Front wheel wells - sealer under black paint. Sound deadener over black paint (after car is assembled)
« Reply #3 on: January 02, 2015, 07:32:15 PM »
hi
yes that helps alot
so seam sealer went on before paint and sound deader went on after paint
thanks
barry
« Reply #4 on: January 02, 2015, 07:36:22 PM »
hi
also on my car only the drivers side has seam sealer and not on passenger side could that be factory
cheers
barry
« Reply #5 on: January 02, 2015, 07:37:44 PM »
hi
Might have been during the transition between the two methods
hi
yes that helps alot
Correct - Firewall sealer went on after paint also
