Hi, my first post! I am putting together my 66 hardtop, and am scratching my head over fitting the outer steering column. The shaft from rubber damper to end is 36 inches. The outer column is 35 inches. But I need the shaft to stick out another 3/4 inch or so to accommodate the steering wheel and nut. I've had the column apart to install new wiring, but it all appears to be back together correctly. Is it possible to reassemble that incorrectly, didn't seem so to me, but it must be wrong somehow? Note, in the photo the plastic bushing is shown displaced outwards, it easily pushes in. Thanks for any help, I am probably missing something terribly obvious. And yes, the painter got a bit carried away with painting the column...
