Author Topic: Exhaust Hanger Rivets  (Read 2353 times)
Offline 70 Yellow B2
« on: December 23, 2014, 02:32:17 AM »
I am in the process of restoring my original exhaust hangers for my '70 BOSS 302.  Does anyone have a source for the 3/8" dia. flat head semi-tubular rivets or someone who does this riveting?  I found the 1/4" X 1/2" rivets but not the others.
Tim
1970 BOSS 302 - Yellow on White
0F02G150833
Offline Scott Fuller
    • Scott Fuller Reproductions
Re: Exhaust Hanger Rivets
« Reply #1 on: December 25, 2014, 06:49:06 PM »
Are you talking about the forward muffler hangers or rear hangers...or both?
Scott
68 "135" Mustang, 68.5 Blck Mustang CJ Cnvrt, 68 Rd HCS (fact 428), 68 Ac Bl Mustang GT Cnvrt, 68 Ylw GT500KR Cnvrt, 68 Hlnd Grn GT500KR Cnvrt, 68 Gld G.T. 500 Cnvrt, 68 Ryl Maroon Mustang Sprint Cpe, 68.5 Hlnd Grn Fstbck, 68.5 Ylw Mustang Fstbck. Visit my website www.scottfullerreproductions.com
« Reply #2 on: December 26, 2014, 02:08:45 AM »
Scott,
The rear hangers that mount to the frame next to the gas tank.  They use a flat hear semi-tubular rivet that are not stock items anywhere I have looked.  I've tried to have them quoted but the manufacturers want a minimum of 10,000 pcs.  There are two length 3/8" X 3/4" Flat Head Rivets used per assembly.  One would be 1" long where the rubber is doubled and the other is 11/16" long.  The rear hanger that bolts to the muffler uses a more off the shelf 1/4" X 1/2" Oval Head that would be either 9/16" or 5/8" long.
« Last Edit: December 26, 2014, 02:03:52 PM by 70 Yellow B2 »
0F02G150833
« Reply #3 on: December 26, 2014, 12:07:01 PM »
I was unsuccessful in finding the correct flat head rivets too.  So I'm having them made for the new hangers I'm having made.  I'll probably have the rivets/hangers in about 6-months.  I'd be happy to give you some but don't know if 6-months fits your timeline.
Scott
« Reply #4 on: December 26, 2014, 01:39:33 PM »
Scott
It would fit my timeline though, Those rivets look pretty much exactly the same as those in the 67-69 style resonator hangers. Actually, the rivets and rubber hoops look identicle to those in the hangers previously pictured (with the hooped rubber) I have at least one, possibly two that could use the rubber hoop replaced on it (some cracks). Is there a good source for the OE style rubber as well?  That one I could use replacing is the right side & is mostly all black rubber, the two driver's side resonator hangers I have are both mostly white rubber and one looks rather good, while the other white LS hanger is middle-of-the road quality.
« Reply #5 on: December 26, 2014, 02:01:40 PM »
The rubber on these hangers are actually made from the sidewalls of tires.  Most of mine from two full sets have the whitewall section running through them.
Scott, that would be great!  The timeline will not be an issue.  I have two sets of originals that I am restoring and a new reproduction set.  I have only disassembled one set of the originals so if I get to that point I will use the repops in the interim.
Thanks, Tim
0F02G150833
« Reply #6 on: July 25, 2015, 01:12:27 AM »
Scott, were you able to get these rivets? I still need to rebuild my hangers. Let me know are interested in doing assembly.
Tim
0F02G150833
