Author Topic: 70 Dearborn 428 CJ Engine Paint Marks  (Read 4892 times)
« on: December 19, 2014, 09:55:45 PM »
Disclaimer: :) As always we need to warn that unrestored does not always mean unaltered by previous owners. Just because this car has/had a specific detail does not mean your car was built just the same. Always do your research, document your findings and make the best choice for you and your expectations.
Now that the standard warning is out of the way was labeling pictures again today and thought some of the site members might find these interesting even though the mast majority of them would never be seen on a finished car.
Car is a 70 Dearborn built CJ that had reported to have never been apart before and was being disassembled to check the workings and get new gaskets.
VIN starts with #123xxx putting it somewhere in November 69 for a possible car completion date.
Have seen many of the same markings on other examples
Lifter Valley
Drivers Side Head rear surface & Rear Block colors VIN was found on the rear surface of the drivers side head
Passenger Side Head & Rear Block colors Arrows highlight the end of the crankshaft mark, back of block mark and a paint/color transfer from the automatic filler tube
Drivers Side Head front face
Passenger Side Head - White stripe under the Engine ID sticker location
Hope these help others in their Concours endeavors
Offline Mike_B_SVT
Re: 70 Dearborn 428 CJ Engine Paint Marks
« Reply #1 on: December 20, 2014, 01:22:23 AM »
Thanks Jeff!  Good stuff :-)
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
Offline markb0729
  • South Jersey
« Reply #2 on: December 20, 2014, 02:41:32 AM »
I love this stuff!!!
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
« Reply #3 on: December 20, 2014, 01:15:44 PM »
any pic of rh panrail area just below freeze plugs   starter cable routing? thanks
« Reply #4 on: December 20, 2014, 03:53:01 PM »
On this car the engine was out and apart when I got access to it so no pictures from when the starter cable was still routed on/near the engine
When I saw this car that first time the cable was still attached to the solenoid and to the starter which was sitting on the strut rod support
« Reply #5 on: December 21, 2014, 06:04:01 PM »
note the shorter rounded corner J strap & writing on cable   wonder if 2 j-straps &  dota starter?  lokks like ca emission blue canister
« Reply #6 on: December 21, 2014, 07:31:06 PM »
Can't  tell - from all the angles the starter cable was sitting under the vapor canister and I didn't take the time to move everything around
  looks like ca emission blue canister
Yep - local car. Will post some additional pictures of the car in a new thread - unrelated to the engine block assembly.
As always - never get pictures of everything nor have hours to go over most cars :(
Offline Mike_B_SVT
« Reply #7 on: December 22, 2014, 04:30:08 PM »
wonder if ...  dota starter?
Should it be a D0TA starter?  CJ site lists D0TF as the correct starter for a '70 CJ.  I tried searching the various sites, but there seem to be few (if any) examples from original cars.
I crossed my fingers and crawled under my car to check the starter, but I have a D0AF with a Jan '71 date code :-/
Mike B.
Cat Bites Man!
« Reply #8 on: December 22, 2014, 05:33:14 PM »
yes dotf id on starter & trying to figure out when ford went to that starter from c8af fall of 1969  I am thiking.
