Author Topic: '68 390 motor mounts  (Read 1373 times)
Offline Oz390
« on: June 26, 2014, 03:45:13 AM »
Brackets that go between the frame and insulator/bracket on the block.  Late San Jose build (late April 68).
Believe they should be natural bare steel, and the bolts S2.  Does it vary between X and S, or the same?
8R03S : 76A I 2A 15M 72 5 U
Re: '68 390 motor mounts
« Reply #1 on: June 26, 2014, 08:17:00 AM »
I believe it to be the same for all V8 engines.
Marty
« Reply #2 on: June 26, 2014, 05:24:31 PM »
Yes they are the same 67-69 BB. Not sure on 70 .
Offline Oz390
« Reply #3 on: June 26, 2014, 05:32:36 PM »
Thanks for confirming.  Much appreciated.  :)
« Reply #4 on: June 26, 2014, 09:00:04 PM »
If your refinishing them - remember to return the fresh welded look/discoloration to the welded areas of the mount ;)
