Author Topic: Restoring seatbelts  (Read 2504 times)
Offline Hipo giddyup
Restoring seatbelts
« on: February 22, 2014, 12:53:24 PM »
Does anyone have any tips on re-dying faded seat belts? I have the original seatbelts for my 1964 1/2 coupe but the black coloring has ofcourse faded. Luckily the chrome is in great shape.
Offline suskeenwiske
  • 214-347-3628
Re: Restoring seatbelts
« Reply #1 on: February 22, 2014, 01:33:49 PM »
You may have some luck checking with a fabric or upholstery shop.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline carlizard
« Reply #2 on: February 22, 2014, 01:38:20 PM »
I  had my seatbelts for my 64.5 vert restored by http://www.pythonrestoration.com/.  They are absolutely like brand new.  I've attached a picture that shows a portion of the belts.  I'd do it again with them if ever needed. :)
1964.5 260
Body:   76A
Color:   M
Trim:    89
Date:   30G
D.S.O:  75
Axle:    1
Trans:    6
« Reply #3 on: February 22, 2014, 02:28:22 PM »
Thanks for the reply. Since I have performed about 99% of this cars restoration I would like to be able to freshen them up myself but I'm open to other suggestions. I' m only doing the front since this car did not have any rear seat belts. Do you mind if I ask how much it cost you? If this is not something you want to post publicly you could PM me. Also, what was there turn around time? Thanks
« Reply #4 on: February 22, 2014, 10:02:04 PM »
I cleaned mine up by soaking in hot water with a good dose of simple green, followed up by a good rinse.  Finally, RIT dye was used to freshen up the color.  Someone way back in 1998 told me about this method on VMF (Speegle?  Turner?).
Offline 69RavenConv
  • Owner since '74
« Reply #5 on: February 22, 2014, 10:10:28 PM »
I did something similar but used Woolite instead of simple green. It worked well.
Phil
'69 Convertible - Dearborn June 4, 1969 - Raven Black & Red - 302-2V
« Reply #6 on: February 23, 2014, 12:49:02 AM »
That sounds good. Do either of you know the ratio of simple green/ woolite to water?
Offline 69RavenConv
  • Owner since '74
« Reply #7 on: February 25, 2014, 11:32:25 PM »
It's been a while but I'm sure I just followed the directions on the Woolite bottle for hand washing -- maybe a little stronger. Simple green is pretty gentle, I should think the consistency of dishwater would be good?
« Last Edit: February 25, 2014, 11:37:58 PM by 69RavenConv »
Phil
