Author Topic: When to replace tires from age  (Read 204 times)
Offline lightwtjet
« on: November 19, 2024, 10:02:49 PM »
   Manufacturers recommend replacing car tires every 6 years and for sure by 10 years. Trailer tires (ST) should be replaced every 5 years. I have exceeded those numbers on vehicles with low miles, and garage kept, but I have also had tires on my boat trailer blow out unexpectedly without any visual suggestion they were failing.
On insurance claims of tire-related incidents it was found that 77% occurred in hot-climate states, and 8 4% were based on tires more than six years old.
I have reduced speeds knowing these facts. What are your findings?
1968 CJ - Owner and paint original. Dec 67 build in Dearborn. One of 50 135 Cobra Jets. Ford engineering used it for 8 mos. to resolve problems in the 50 early car build. Ford by-passed the normal sign off to get cars to the Winternationals drag race.
Re: When to replace tires from age
« Reply #1 on: November 19, 2024, 11:28:34 PM »
It looks like you have the prevailing information from what have been told by all the tire stores .
« Reply #2 on: November 20, 2024, 12:01:56 AM »
Back before al the warnings I'm pretty sure many of us ran tires well past the Use by date writing about in more recent years. Now with this knowledge and if you accept it or reject it is up to you. Damage from past due tires through the insurance may be an issue for you or others but bottom line is that you have to make your own choices since your the one that has to live with the results.
Found that I dislike replacing brand new but old tires so often since many are just holding the cars up off the ground. Also have purchased tires over 6 years ago that have never been put on a car as of yet. Please do not follow my choices their mine, mine, mine  :)
Offline rhjanes
« Reply #3 on: November 20, 2024, 10:17:40 AM »
I've walked out and found an exploded trailer tire once or twice.  One time I was working on the yard, and looked at a trailer and thought "Why is that cat perched on top of the tire?"   Then I realized the cords had blown out and the "Cat" were thread of the steel belt.  Trailer tires just up and die, sometimes quickly.  I think trailer tires are stretching it past 5 years.  My 1969 Coupe had a "Gas Station" tire for a spare.  It was in there probably from the late 1970's.   Last set of tires I put on (car sits inside), I decided to do the spare.  The tire man told me when they put it on the dismount tool, the tire just broke...hard rubber.
1969 Mustang Coupe, 302-2V, auto, air, PDB, Lime-Gold.  In the family since 1972
1969 Mustang Mach 1, 428 CJ Ram-Air, Auto, air, PDB, PS, Grabber Orange.  Self restored (for the most part).
2008 Mustang GT Convertible.  Weekend driver.
Always looking to learn and improve the cars.
Offline BobV
« Reply #4 on: November 20, 2024, 11:09:16 AM »
It depends....
Below is a tire that was 8 years old, BUT the car had sat. Outside. With that side exposed to the sun.
When I bought that car, I checked tire pressures & fluids and headed home; the result below happened 100 miles later. Could have been disastrous. Sounded like a couple rocks popping out of the tread at 75mph, then it BLEW 3 seconds later.
A car that sits inside, out of sun / ozone, I MIGHT consider 10 years for local use, with frequent checks. If I'm going to travel, nope, 7-8 years is it.
I had to replace tires on the 86 Saleen last year after ~12k miles over 9 years and 100% indoor storage (with 75% tread remaining). Had a roundtrip drive from Kansas City to Albuquerque. Just not worth the risk. Same situation coming up next year with our late-model...
« Last Edit: November 20, 2024, 11:25:28 AM by BobV »
1986 Saleen Mustang
51k miles 98% original
