Author Topic: Hello. This Is The Service Department Calling -  (Read 1368 times)
« on: October 17, 2020, 12:30:01 PM »
Having a bad day, are you?
Offline kkupec02
Re: Hello. This Is The Service Department Calling -
« Reply #1 on: October 17, 2020, 10:45:21 PM »
We have all dealt with shops like this.
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
Offline JohnSlack
« Reply #2 on: October 20, 2020, 03:10:41 PM »
The first oil change in my 2010 GT I'd taken to the dealership and had it changed. I got the car back and there was a humming vibration over 59 mph from the steering column. Luckily when I took it back to the dealership to have that looked at a more seasoned "technician" looked at it. There is a plastic fairing on the bottom of the car that you remove to change the filter. One of the screws on it was not tightened and as you got over 50 MPH it would vibrate and send the harmonics right up the column.
9F02G217159 1969 1/2 Dearborn BOSS 302 built July 10, 1969 1 day behind
Calypso Coral 2A 61 DSO V 3.91 Trac-Lok 6 Close ratio Retail Bob Brock Ford
0F02G106990 1970 Dearborn BOSS 302 built September 23, 1969 13 days behind
Lime Metallic EG 71 DSO S 3.50 Trac-Lok 5 Wide ratio Stock John E. Noyes Ford
