What is the correct length for a 68 Shelby valve stem extension? I have one that was on the car that I thought was original and it is almost 1 inch with a metal cap. The reproductions are 3/4 of an inch with a white plastic cap. Also did the spare have the extension?
The 1 1/4" looks right. Probably best to check w/Pete Disher.
OK Hub cap king reporting in. First of all it’s important to remember when you are reading the extension length that is the way that it extends the valve stem and not the overall length of the extension. The extension screws on the valves them about 3/8 of an inch so if it says three-quarter inch extension will measure 1 1/8 but extend the valve stem 3/4From A.O. Smith inventory records I show that both the B2 and the C2 were used. I have actual packages from original cars that have the C6 C2 stamping on them. It appears that both were used but the C2 give little more length probably a better choice. In any case originals had metal balls and not plastic
I have one unopened original package (not service parts) from an original box of hubcaps and it has 4 extensions in the bag with 4 blue plastic washers that would go up inside the extension. Their overall length is 1-5/16 (plastic) not including the metal ball.
And your website is down.Jim
I have one unopened original package (not service parts) from an original box of hubcaps and it has 4 extensions in the bag with 4 blue plastic washers that would go up inside the extension. Their overall length is 1-5/16 (plastic) not including the metal ball.Scott
