1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: Brian Conway on July 09, 2014, 01:18:34 PM
Title: Trunk Filler Board ?
Post by: Brian Conway on July 09, 2014, 01:18:34 PM
Searched assorted combinations of ' 69 trunk filler board ' and no results.  Did the 69 cars get the trunk filler board ?  My 65 has one and it is held in place with two large Phillips head screws into the sheet metal.  No evidence this method was used in my 69 FB.  Brian
Title: Re: Trunk Filler Board ?
Post by: J_Speegle on July 09, 2014, 05:51:22 PM
Yes there was one used (on the drivers side) but unlike the 65-67  Ford changed mid way (well approx ;)  in 67 to a heavy cardboard design that had "wings" that folded down ward and sort of held itself in place Since this is the 69-70 section would mention it was also installed on 70's without the Calif emission systems
Post by: Brian Conway on July 09, 2014, 06:04:31 PM
Thanks Jeff.  Never seen one before and does explain the absence of screw holes.   A search ' 69 trunk underlayment ' did show a 70 with a partial pic.  Brian
Post by: J_Speegle on July 09, 2014, 06:10:29 PM
Either I or someone will post a picture of one installed - lots of pictures to go through and I often won't fold back a mat
Pictures of the cardboard  would be available on NPD or Virigina sites (or should be ) but would only show the panel flat with out the "wings" extended
Post by: J_Speegle on July 09, 2014, 08:33:49 PM
Here is a picture (happens to be a 68 example but the same piece)  of a very very nice original
(http://www.concoursmustang.com/forum/gallery/2/6-090714183242.jpeg)
Post by: Brian Conway on July 09, 2014, 10:24:11 PM
     Thanks for posting the picture.  You know that adage " a thousand words " I could not figure out how the ' wings ' worked.  I Was looking at some catalog pictures of the filler board and was disappointed to see that they don't seem to be configured correctly and also have neglected to put the slot in for the metal ridge on the wheel house.  Brian
Post by: Anghelrestorations on July 11, 2014, 10:38:00 PM
I dont know if the slot was originally on the boards from what I have seen.  Here is pictures of what I think is an original and reproduction side by side.  And also a close up of the material as well.
(http://i191.photobucket.com/albums/z213/azscj/DSCN7265_zps921dd809.jpg)
(http://i191.photobucket.com/albums/z213/azscj/DSCN7266_zpsb29e43b2.jpg)
Post by: Brian Conway on July 11, 2014, 10:44:22 PM
     Thank you Marcus.  Appears the after market piece is a fairly accurate reproduction.  Brian
Post by: J_Speegle on July 12, 2014, 04:09:17 AM
Double checked and the example I posted is a 67-68 :(   gave the wings and the material - just not the original shape
Post by: Mike_B_SVT on July 15, 2014, 04:12:48 PM
Related question / clarification...
I have a '70 Cougar with CA emissions (Oct '69, Dearborn car).  So I should not (and do not currently) have a driver's side filler board.  But should I have a passenger side filler board?
It seems that all the kits include a pair / set.
Thanks!
Post by: J_Speegle on July 15, 2014, 09:30:23 PM
Correct - since there is no room for it with the base plate and all the vents and hoses as well as the taillight sequencer
Correct - one on the passenger side - unlike the Mustangs. Likely due to the different mounting location of the spare tire
Post by: drummingrocks on July 17, 2014, 10:31:51 AM
Brian, not to get off topic here, but are those rubber insulators behind the nuts for the side marker light original?
Post by: Brian Conway on July 17, 2014, 10:47:11 AM
Yes they are.  NOT OE.  I put them on there just because.  Good eye.  Brian
Post by: Mike_B_SVT on July 17, 2014, 04:06:17 PM
Thanks Jeff!
