Restoring - General discussions that span across many different groups of years and models => Interior & Trunk => Topic started by: MWM on May 27, 2011, 04:52:16 PM
Hello!
I am in the process of restoring my five gauge cluster and want to know what to use to clean and polish the clear plastic lens? Also, it has a scratches from an over aggressive cleaning, is there a way to get some or all of the swirls out?
thanks!
i have used meguiars plastic cleaner and polish with good success. if the scratches are very deep you may have to replace the lens to get the desired result.
Semi-chrome polish or similar product will remove allot of damage I use it for headlights (newer plastic ones) on newer cars. Or you can always just purchase a headlight repair/refinsihing kit for the newer cars. Run about $20 and come with an attachment for your home drill
Thanks everyone for your suggestions! I used the meguiars product WITHOUT the drill attachment, but by hand using the cloth supplied. Most of the scratches and pitting came out and it is very clear! I am very happy with the results.
3M finessit II swirl remover polish works well when used with micro fiber cloth. Chuck
