1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: asrassoc on July 01, 2023, 01:59:59 PM
Title: Steering Wheel after restoration color verses faux wood dash and door inserts
Post by: asrassoc on July 01, 2023, 01:59:59 PM
Good afternoon all.
Just received both my original steering wheel as well as my dash clusters back from the respective restorers.
Attached are pics of the restored wheel and the clusters BEFORE restoration.
Restored wood grain on the wheel is much darker than faux wood on the dash pieces. Do these fade over time?
Should I look at replacing the faux woodgrain with repros?
Title: Re: Steering Wheel after restoration color verses faux wood dash and door inserts
Post by: jwc66k on July 01, 2023, 04:15:45 PM
I'm missing something. The "BEFORE" restoration pictures. Are there 'AFTER" restoration pictures?
After time, say a solid ten years of normal use, the finish will get noticeably worn. I got in the habit of wearing deerskin gloves to reduce the perspiration from my hands getting on the steering wheel and the slipping and sliding on the restored (or new in my case) wheel thru both hands. I learned to drive in New England (snow, rain, humidity, rust reside there) so I wore gloves all the time. I still wear gloves but the driving is on the West Coast.
Post by: J_Speegle on July 01, 2023, 06:33:03 PM
So just to clarify. You have a pretty or very early Mach I with the light woodgrain inserts on the dash and door panels and your concerned that the tone or color of the steering wheel does not match or is even close to the dash and door panel coloring?
As for fading of the steering wheel I would not expect or anticipate that it will lighten over time.
Post by: HDAshmore on July 01, 2023, 09:22:53 PM
After restoration pics?
Post by: Bob Gaines on July 01, 2023, 09:57:06 PM
Good afternoon all.
Early 69's had the light teak and later had the dark dash and door panels. With that said I have only seen the shade of darker walnut faux finish used on the steering wheel rim re regardless of early or late which gives me a high confidence level that was typical. You should not be surprised that the light teak does not match the dark walnut steering wheel. If they did it would be perceived as not factory.
Post by: asrassoc on July 02, 2023, 03:40:10 PM
Thanks Bob!
THe only pics I had of the dash clusters was before I sent them to be restored.  Had already repackaged them to store until ready.  the 'teak" on the pics I posted appear to be the factory original ones and are in good shape so I'll use them.
