1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1968 Shelby => Topic started by: ruppstang on November 22, 2020, 10:15:04 PM
Title: 68 GT 350 tilt vacuum clamps
Post by: ruppstang on November 22, 2020, 10:15:04 PM
Recently our 68 GT350 built 12-02-67 was judged and deducted for having a incorrect tilt vacuum clamps in the forward location and the one in the center of the shock tower that should not be there.
Today I looked at a unrestored 68 GT350 and found the front location empty and the center with the base of the clamp still intact. Does some one have some pictures of what is correct location and style of clamp?
Title: Re: 68 GT 350 tilt vacuum clamps
Post by: Bob Gaines on November 22, 2020, 11:06:46 PM
All I could put my hands on at the moment is a couple of broken clips.They get very brittle. One has the bottom tab that plugs into the hole missing and the other has the bottom tab intact but the upper portion broken.You can get the idea from using parts of both to visualize what a intact one looks like .They would go in the holes that the big clamps in your picture occupy.
Post by: Coralsnake on November 23, 2020, 01:10:42 AM
That is the clip for your car. In the front position only. I believe the back position is usually absent or a thinner strap.
Your example appears to have a couple other items that appear to have been changed so may not be reliable.
The clip Mr Gaines pictured is not used on all 1968s and definitely not KRs
Post by: ruppstang on November 23, 2020, 09:31:56 AM
The unrestored car has been off the road for many years it seams unlikely that someone would bother to replace one of these clamps. The is however a later build 04-04-68 so may have used a latter style clamp. What is left of the clamp appears to be similar to what I used on our car.
Pete pictures of what you think is correct would be helpful.
I have not seen any of these clamps reproduced so if someone has some to sell please PM me.
Post by: Coralsnake on November 23, 2020, 10:52:53 AM
We can agree on the front clamp, it is the one Mr Gaines posted. It is not reproduced, but found on other Ford products.
As for the rear strap, let me see what I can find, but I fell confident in saying what you found is atypical and unusual.
Remember the Shelby wiring was added later, so it does not go through the rear strap.
Post by: CharlesTurner on November 23, 2020, 11:52:20 AM
The general rule is that if there's a hole in the front area of the shock tower, it should have one of the unique clamps for the Shelby wiring.
Post by: Coralsnake on November 23, 2020, 12:41:04 PM
I believe the rear strap should be like the plastic, windshield washer hose strap on driver’s side
Post by: Bob Gaines on November 23, 2020, 04:37:56 PM
This later 68 production GT350 example confirms your belief.
Post by: ruppstang on November 23, 2020, 08:53:52 PM
Thank you gentlemen, that helps a lot.
Any ideas on what other Fords and where they used the front clamps?
Post by: 67gta289 on November 23, 2020, 09:17:02 PM
If we can pin down a part number we would have a much better chance of finding other applications.  Here are a few candidates from the 1965, 69, and 75 Ford standard and utility parts catalogs.  Do any of these match up with a known one?  Another option would be if anything is listed in a Shelby drawing.
Once we have the part number we can search through Jim's fastener spreadsheets and I can do text searches on multiple years/versions of the MPCs.
Post by: Bob Gaines on November 23, 2020, 09:51:21 PM
352357 S looks like it.
Post by: 67gta289 on November 24, 2020, 06:31:03 AM
So for 352357-S (GG-323) I found:
1. No hits in the 1965 MPC
2. One hit in the 60-68 MPC
   (picture 2) 1967 Thunderbird wire harness in the engine compartment along the driver's side
3. Hits in the 65-72 Ford MPC
   (picture 1) 1967/68 Ford 14290 wire harness in the engine compartment along the driver's side
   (picture 2) 1967-1969 Thunderbird wire harness in the engine compartment along the driver's side
4. Hits in the 65-72 Mercury MPC
   (picture 3) 1968 Cougar fog lamp and sun roof circuit breaker feed
5. No hits in the 73-77 MPC
I think that picture #3, being a Cougar, and looking at the location which matches the Shelby application, lines up pretty good.
Maybe someone with a fog lamp and/or sun roof equipped 68 Cougar can post some pics?
Does the 68 Shelby assembly drawing show this part and identify the part number?
Post by: ruppstang on November 24, 2020, 08:40:14 AM
Thanks John for you search. It makes me feel a bit silly for not checking the Shelby assembly manual first. The other ford models and locations are helpful on my search. I had better get to the junk yards before they are covered in snow.
Post by: 67gta289 on November 24, 2020, 08:50:05 AM
No problem at all.  If you don't find anything let me know; the yard I go to has plenty of 67-69 T-birds and 67-68 Galaxies.
Post by: RoyceP on November 24, 2020, 10:58:59 AM
That clip is only used on Cougar XR7-G with sunroof. So approximately 437 cars total. They are usually missing or broken.
I think they are not used on typical 1968 Mustang / Cougar with tilt away. Maybe Shelby only for some reason? It would make sense since the 1968 Shelby and XR7-G Cougars were both modified at AO Smith for Shelby Automotive.
Post by: krelboyne on November 24, 2020, 11:34:27 AM
Maybe a 1968 Metutchen factory thing?
Post by: Bob Gaines on November 24, 2020, 01:34:20 PM
Nice work on the search. The 3 along the driver side in your first picture is where I typically find them. You are lucky if you can get one out intact. Like I said before they get brittle and are very fragile. Thanks.
Post by: krelboyne on November 24, 2020, 01:41:37 PM
It was done at AO Smith
Trying to understand this thread. The tilt vacuum hose clip, on a 1968 Shelby Mustang, was changed or added at A.O. Smith?
Post by: CharlesTurner on November 24, 2020, 02:39:25 PM
The oddball clamp was for the Shelby console gauge wiring.
Post by: RoyceP on November 24, 2020, 06:42:58 PM
Or for the sunroof power feed if it is on a Cougar XR7-G.
Post by: 67gta289 on November 24, 2020, 06:46:14 PM
Or Ford and Thunderbird applications listed in reply #14  8)
Post by: rodster on November 24, 2020, 08:16:10 PM
I found my clamp already out and intact.  I'd say that was lucky.  ;)  I don't often have much to contribute here but am familiar with this clamp. Attached are some photos for reference.
Maybe a project for 3D printing?
Post by: TLea on November 24, 2020, 08:51:29 PM
67 full size Ford on firewall
Post by: ruppstang on November 25, 2020, 09:26:14 AM
Wiring only or were the tilt vacuum line in it as well?
Post by: TLea on November 25, 2020, 12:17:38 PM
ammeter wires, tilt hoses (cars built before 12/1/67) and sometimes convertible wire feed
Post by: jwc66k on November 25, 2020, 04:01:53 PM
As a hobby, one of my neighbors has done 3D printing for a couple of years now, and he says - no - with reservations. The media he uses is lactate based (milk). That media will not stand heat, it melts. There are other "medias" available but they require high dollar printers. Still, for low volume production, it would be something to look into.
Post by: CharlesTurner on November 26, 2020, 12:23:14 AM
I heard the same thing when exploring the possibility of 3D printing a group 22 battery case.  They said a different type of media had to be used and at that time the only color was white.
Post by: J_Speegle on November 26, 2020, 09:02:36 PM
We had the same issue back in the late 90's when a friend had some 70 battery shields made. Ended up just painting them and they did the job just had to watch for nicks and chips in the paint and touch them up.
Post by: Colorado56 on November 26, 2020, 10:32:00 PM
My Shelby was  built 12-1-1967. Would the tilt hoses still go through the clip with the ammeter wires?  I also have that style of clip on my car.
Post by: rodster on December 01, 2020, 08:49:54 PM
Good info on 3D printing.
Print several and when one melts, just replace it.  ;)
3D printing is the future.
Post by: TLea on December 01, 2020, 10:36:59 PM
Like I said sometimes. Either can be correct
Post by: Colorado56 on December 02, 2020, 12:50:20 PM
Post by: ruppstang on January 25, 2021, 11:25:07 AM
I thought it was interesting that in the unrestored section here there are two threads on unrestored GT350's and neither of them have the 352357-S clip. I am wondering if a number of cars were built with a alternative clip or strap.
