1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: 1970 Snake on October 08, 2019, 05:28:10 PM
I am in the process of getting my 3 rivet upper ball joints riveted on to the control arm and would like to know if the original factory ball joints had a shield holding down the rubber boot or was it glued or how was it held down to keep the grease in?
(http://www.concoursmustang.com/forum/gallery/12/6-081019203811.jpeg)
(http://www.concoursmustang.com/forum/gallery/12/6-081019203747.jpeg)
(http://www.concoursmustang.com/forum/gallery/12/6-081019203730.jpeg)
Thanks Jeff, looks like there was no shield holding the boot down, possibly just some type of adhesive.
No adhesive. The tie rod boots evolved the same way. once tightened down the boots stay in place.
Ok great thanks Bob much appreciated, just assumed something held them down to stop the greasing process from popping them off the ball joint as newer versions either have the shield or a spring ring clip to hold the boot in place. My concern was if there was a shield it would need to be riveted in place with the ball joint.
The new improved 1970 and up d00z upper boot was designed to be easy replacement when damaged vs the previous years when u had to remove 4 rivets to replace damaged grease boots. Problem is u cant find the dooz boots by themself so I sent an nos dooz upper boot to carpenter years ago to make but dont think it ever got made. Does anybody know where u can get the dooz boot or any replacements?
hi specialized, the picture I have posted is of my original ball joints which I have refurbished and I believe I have the latest replacement boots available on them, the boots can be purchased from a number of vendors.
Part Numbers are C70Z-3105-B for the upper ball joints and C70Z-3105-A for the lower ones, your search engine will find vendors.
The correct 70 upper boot has dooa-3ao47-a # and UPPER on it by small hole and a metal ring moulded in bottom boot big end hole that is pressed in place around the ball joint so boot dont come loose when greased and originals are very hard to find thats why i was trying to have them made as they fit all 70 and up upper 3 rivet a-arms. The c70zs have no metal reinforcement ring moulded in them so they need the extra retainer ring to hold them in place before being riveted on. The bottom lip on the dooa boot is much thicker having the metal ring in it than the thinner c7oa bottom lip on the boot.
Whoever is doing the rivets on the control arms should know what the correct boots and how to do it.
But those boots you have in the photos will not work. This is what the correct boot looks like that Ed is talking about.
(https://live.staticflickr.com/65535/48871975592_c34a40aa1c_z.jpg) (https://flic.kr/p/2hsDDEQ)20191009_113435 (https://flic.kr/p/2hsDDEQ) by Marcus Anghel (https://www.flickr.com/photos/154714213@N02/), on Flickr
(https://live.staticflickr.com/65535/48871975587_0828310cc4_z.jpg) (https://flic.kr/p/2hsDDEK)20191009_113444 (https://flic.kr/p/2hsDDEK) by Marcus Anghel (https://www.flickr.com/photos/154714213@N02/), on Flickr
(https://live.staticflickr.com/65535/48871779846_f5fb12fe49_z.jpg) (https://flic.kr/p/2hsCDtU)20191009_113505 (https://flic.kr/p/2hsCDtU) by Marcus Anghel (https://www.flickr.com/photos/154714213@N02/), on Flickr
(https://live.staticflickr.com/65535/48871779831_aa7259fb63_z.jpg) (https://flic.kr/p/2hsCDtD)20191009_113514 (https://flic.kr/p/2hsCDtD) by Marcus Anghel (https://www.flickr.com/photos/154714213@N02/), on Flickr
Thank you for the detailed information gentlemen, I realize the boots I have are not the NOS boots, but as far as I know are the only ones available now to replicate the originals. I am also guessing the ones you have posted the pics of are very difficult to come by and if found would be cost prohibitive. Marcus can you please advise why the C70Z boots will not work.
https://www.ebay.com/itm/303114491879?ul_ref=https%253A%252F%252Frover.ebay.com%252Frover%252F1%252F711-53200-19255-0%252F1%253Fff3%253D2%2526toolid%253D10001%2526campid%253D5338313242%2526customid%253Dvintagetruckscarspartsdays.com%252Bsingle%252Bd0oz-3a105-a%252B85.166.174.245%2526item%253D303114491879%2526vectorid%253D229466%2526srcrot%253D711-53200-19255-0%2526rvr_id%253D2139084949806%2526rvr_ts%253Db1f2894316d0a4d1295183c9fffaefa7&ul_noapp=true
Thanks, I see they do come available every now and then, unfortunately these my cost shipped would be about $275 Canadian and that for me is very cost prohibitive, when the C70Z repros are about $12 each.
The original boots will keep the grease more in check because of the thicker reinforced edge of the D0 boot compared to the thinner edge of the C7 which was designed to have the ring hold it down . It may have been more prudent to replace the entire arm ball joint and boot as a unit with a service 3 rivet arm or repro given the compromise on the boot and the time and effort spent on refurbishing the original arm ,ball joint assembly. But that was then and this is now. I haven't worked with your combination of 70 arm a C7 boot before but I don't think it will be a big problem from a maintenance standpoint. I would guess it will be just cleaning up of a little grease that gets squeezed out from under the boot every so often after driving on rough roads. On the plus side the grease will automatically help keep corrosion in the area to a minimum . Just some thoughts for the discussion . Others may think differently.
So if I understand Ed correctly, I can use one of the D00z boots shown in Marcus post to replace my torn boot on my Ford service replacement upper arm without having to remove any rivits?
Thanks Will
Yes
Hi Bob, thanks for your input. I am building the car as a show car but also will drive it a little. I know that the hard core concours guys will freak out at what I am doing but its my car and am building it for me. I am trying to replicate the concours look and details but with tweaks to somewhat do what we did in the day to our new cars, like headers bigger tires etc. yet still maintain the factory details. If this car ever see's 1000 miles once complete I would be surprised let alone bumpy roads and grease weeping out. I have pretty much powder coated, ceramic coated, plated or painted every piece on the car to replicate the look and color of the original pieces, why because I want to drive it and have the metal protected. I do have some NOS suspension replacement parts I can install not quite exact but I want to use my rebuilt originals on the car. I have used SD uppers and lowers to dummy up the suspension and will install the refurbished uppers and lowers for final assembly. I have attached several pictures to show the NOS parts I have and a shot of the front of the car to show you what I am doing. I have considered all the comments in this thread and am going to install the C7 boots on my original ball joints and will use an adhesive to hold the bottom of the boot to the ball joint, as the glue will never be seen and will work like the metal ring on the D0 boot. I would like to use the DO boots but feel the huge cost for those can be spent better else where on the car. Again thanks for all the input, BTW I particularly liked the article you did on the Boss rear axel rebuild to factory original details, I have pretty much redone mine to the same standards including a custom paper tag from Deadnuts which they made for me as my gear ratio was unique for the year and engine tranny combo.
That was Bob Perkins and not Bob Gaines that you refer to that was in the magazine article . ;)
sorry yes you are correct, nice article though
