Restoring - General discussions that span across many different groups of years and models => Processes, Products & Techniques => Topic started by: Bossbill on October 08, 2019, 03:14:36 PM
Title: 9" gasket
Post by: Bossbill on October 08, 2019, 03:14:36 PM
After looking and buying a few 9" carrier to housing gaskets I found one I like.
It looks a lot like the Ford black gasket, is twice as thick as the paper gasket NAPA sells and is made from high tech gasket material:
https://www.ebay.com/itm/Ford-57-79-9-Inch-9-Axle-Carrier-Gasket-Quality-Interface-8090-Material-DMT/291941140152?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
These guys, Detroit Muscle Technologies LLC, mostly do MOPARs but I like their gasket!
Title: Re: 9" gasket
Post by: J_Speegle on October 08, 2019, 03:40:47 PM
Unfortunately for our focus this one appears to have the name of the material provider plastered all over (guess its both sides) the gasket and that may be visible thought and around the edges of the third member unlike the original plan gasket
Might improve it the gasket was painted or dyed and hopefully the increased thickness is not a detail that sticks out. Just some observations
Post by: Bossbill on October 09, 2019, 12:30:06 AM
The gasket on my 3rd member -- which appears to never been apart and still had the original copper washers -- was quite thick. About as thick as this new gasket.
The NAPA and other gaskets are extremely thin -- they are half the thickness.
0.0175 vs 0.350 for the Ford and this gasket.
I'll post a pic of this gasket on the third member so you can judge how large it is.
Post by: Bossbill on October 09, 2019, 05:05:40 PM
I took a picture from Perkin's article on rebuilding a 9". I know not to use the details for my car, but the Ford gasket is shown on a cleaned up housing. I put this Detroit gasket on my housing and the fit is very close to the Perkins.
The new gasket only has writing on the one side.
In the next pic I show the new gasket with a NAPA gasket. Wrong color, wrong thickness.
If anyone has an original Ford gasket I'd be interested in its thickness.
Post by: J_Speegle on October 09, 2019, 06:12:56 PM
From your earlier post I didn't understand that the factory (gasket maker) markings were only one side.
Makes allot if difference ;) Sorry don't have and original gasket to compare.
Post by: Bossbill on October 09, 2019, 06:48:07 PM
SNIP
A lot of times I'll take a pic in the shop and then post while in the house many hours later. I didn't know the backside was plain either!
Post by: 67gta289 on October 09, 2019, 07:07:51 PM
I've got a couple of NOS ones in Ford cardboard package - is there interest in detailed pics and measurements?
Post by: Bossbill on October 09, 2019, 07:41:25 PM
Yes, especially thickness!
For extra credit, how black is it?
https://www.mediacollege.com/video/test-patterns/grayscale.html
Post by: rockhouse66 on October 09, 2019, 07:50:29 PM
That super thin paper gasket is what I found when I took the diff out of my very original '69 Mach 1 that I sold recently.
Post by: 67gta289 on October 10, 2019, 08:21:19 PM
I could not find the 9” stash, perhaps all sold.  But for NOS C9OZ-4035-A the thickness is 0.0325”.  Pictures attached. Maybe this helps...maybe adds confusion. Hopefully the former
Post by: Bossbill on October 10, 2019, 09:22:57 PM
I like how you put the gasket on items that have a color we can identify.
The thickness is in line with the one I took off my housing. I thought it was original based on other clues such as copper washers that few seem to put back on, original axle seals and bearings and original pinion gasket. I understand those are all clues and not definitive. ;)
Thanks for the data point.
Post by: OldGuy on October 15, 2019, 06:50:23 PM
Bossbill is 100% correct. I just took delivery of a couple of these gaskets upon his recommendation. They're clearly the best I've seen/purchased in a long time.
Thanks for the tip B-bill.
Frank
Post by: bjf1992 on May 20, 2020, 10:01:33 PM
OLD topic, however I am now realizing I screwed a few things up on my rear axle.
I am planning on using this gasket.
This is the first time I have messed with working on a rear axle.
Did the factory use any sealant in conjunction with the gasket originally?? If not, should I use some now?
(I am pulling mine apart...for some dumb reason I though nothing was used......)
Also, when I pressed new bearings on the 31 spline axles I didn't buy new sleeves, I just used the smaller seal used on the 28 spline axles as I didn't know you could buy them at the time.
Will this cause any problems? Should I go ahead and get the sleeves and correct seals while the thing is apart to fix my first mistake :)
Title: Re: 9" gasket sealant
Post by: krman on July 11, 2020, 03:18:46 PM
Didn't see a response to last inquiry but wondering myself- Did factory use a sealant on nine inch carrier housing gasket and if so what color?
Post by: J_Speegle on July 11, 2020, 05:46:51 PM
Don't know if I have those Assembly Manuals, but have you checked there in the notes?
Post by: jwc66k on July 11, 2020, 06:30:46 PM
That is not covered in the Osborn Assembly Manuals as the item was delivered to the line as a complete assembly. The "best" reference would be the service manual, as Ford Car Parts (aka MPC) usually does not include an assembly sequence, just a "this" goes "there" reference.
Post by: RoyceP on July 11, 2020, 06:43:12 PM
For reference my April 1969 MPC lists the gasket for 9" and 9 3/8" carriers as B7A 4035-A. Apparently after the April 1969 revision the part number was changed on that gasket.
Post by: RoyceP on July 11, 2020, 06:52:34 PM
The axle assembly drawing is a 1970 revision. I don't see any reference to sealant either in the illustrations or in the MPC so I doubt Ford used any.
Post by: J_Speegle on July 11, 2020, 07:01:20 PM
Yes would not expect it to be reflected on the exploded view illustrations. Thanks for looking into the subject - both of you :)
Post by: krman on July 13, 2020, 10:11:52 PM
I received a reply of no sealant used from factory on this one. - Thanks
Post by: midlife on July 13, 2020, 10:53:03 PM
I would recommend you take a quality flat edge to the housing to see how flat it is.  On my 66, it was nearly 0.050 out, and the gasket could not stop the leak.  If you have to use sealant, keep the amount small and out of sight.
Post by: Bob Gaines on July 13, 2020, 10:59:14 PM
+1
Post by: krman on July 18, 2020, 10:26:11 AM
Checked and no sealant used originally- .
Post by: Bob Gaines on July 18, 2020, 04:06:16 PM
The place where they are prone to leak is if you do not use the copper crush washers like the factory.
