Restoring - General discussions that span across many different groups of years and models => Body, Paint & Sealers => Topic started by: CharlesTurner on June 22, 2010, 04:04:42 PM
Title: Staples
Post by: CharlesTurner on June 22, 2010, 04:04:42 PM
Anyone ever looked into what type of stapler would be necessary to install splash shield rubber and the rear interior quarter fuzzy strips?  (65-66 fan shroud rubber pad too!)
Found a couple places that sell them.  Guess I need to figure out the metal thickness first.
Title: Re: Staples
Post by: Skyway65 on June 22, 2010, 04:50:35 PM
Charles- My dad retired from Chrysler many years ago.  They used similar staples on the line where he was.  He mentioned that they had a huge Bostitch stapler that would do those staples with no trouble.  Not much in the way of details but I'm sure the thing must be pretty big!
Title: Re: Staples
Post by: SCJSTU on June 22, 2010, 09:33:04 PM
speaking of staples....my 70 Mach 1 has holes on the radiator support for the hood seal.....
did the staple gun actually shoot the staples through the metal support?.......pretty strong gun/staples?
Title: Re: Staples
Post by: J_Speegle on June 22, 2010, 10:02:55 PM
Yes they did - must have made some noise!!
Title: Re: Staples
Post by: Sunlitgold68 on June 23, 2010, 02:46:38 PM
I would say a high powered Pneumatic stapler like this.....
http://www.amazon.com/Stanley-Bostitch-P50-10B-Pneumatic-Stapler/dp/B000LB6K7A
Title: Re: Staples
Post by: CharlesTurner on June 23, 2010, 03:00:46 PM
That might work.  Would have to find out what kind of thickness it's capable of plowing through.
Title: Re: Staples
Post by: carlite65 on June 23, 2010, 03:14:10 PM
it doesn't look 'bad' enough to me. better be careful with the rebound/richochet though.........
Title: Re: Staples
Post by: bryancobb on June 23, 2010, 03:45:57 PM
I took the cheap but laborious way out when I did my splash shields 20 years ago on my Rangoon Red one.  I drilled (2) 1/32 holes through the steel and the rubber at each staple location.  Then I used 0.030" dia. stainless safety wire to make a staple for each spot.  I put them in by hand, and pecked on them while holding a dolly behind to tighten up the bends.
Title: Re: Staples
Post by: NEFaurora on July 01, 2010, 10:44:05 PM
I use the same method.. In metal areas, I drill super tiny holes and press the staples through, and then bend them tight on the other side, On areas that already have holes stapled such as a radiator support, I take a different approach, I take out the old staples for re-use, put the new rubber over the existing holes, then go on the backside and re-create the original holes areas by marking it in the rubber on the backside of the rubber where the original holes are accessable, then I just re-create the holes in the rubber in the correct areas, and push through the original staples and re-bend...or use new staples and bend them...works like a charm...and you utilize the original staple holes to boot.
Tony K.
