1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: kcodecoupe on May 04, 2015, 03:54:49 PM
Title: 65-67 shifter reverse handle bushings
Post by: kcodecoupe on May 04, 2015, 03:54:49 PM
Where can i buy the 65-67  factory 4 speed shifter handle reverse bushings ,there are two per shifter handle they are located in the chrome (T) that you would pull up on before moving the shifter handle into reverse, i think they are black plastic .thanks,  chuck.
Title: Re: 65-67 shifter reverse handle bushings
Post by: midlife on May 04, 2015, 10:20:53 PM
To install them, you have to remove the shift lockout "wire rope", which is silver-soldered.  That bushing is not reproduced for sale, but folks like Bill Healy repairs them.  He has moved from Olney, MD to either N or S. Carolina, IIRC.  He did mine, and it was great to have it working the way it is supposed to!
Post by: CharlesTurner on May 04, 2015, 11:07:31 PM
Was just looking around for something like this myself as I have a super nice original 4sp shifter, but the bushing is worn at the top and it vibrates when driving.  Bill does install a sleeve, but I notice that his do not have the bottom spacer like originals do.
In the past, I've bought NOS shift handles that have the correct bushing, they are getting a little more expensive these days though.
Has anyone tried to do the silver soldering on the cable end?
Post by: kcodecoupe on May 06, 2015, 07:13:32 AM
Has anyone tried to do the silver soldering on the cable end?  I would like to try silver soldering, i do my own body panel lead work cant see where it would be much more involved, i have a real nice 65 shifter like yours that needs the bushing, it would be cool to do the work at home.
Post by: kcodecoupe on May 06, 2015, 07:18:14 AM
Did the early 64.5 4 speed shifter handle have the reverse lockout bushing as the 65-67 did
Post by: rockhouse66 on May 06, 2015, 08:25:32 AM
Charles
I have silver soldered a new wire (bicycle brake cable) to repair one with a broken wire.  I eventually got the silver solder to stick and work, but I was never able to get the whole thing as tight as an original.  Very hard (for me) to pull the cable tight enough and still have room to do the soldering.  Part of this may be due to working alone or not making some sort of fixture.  I think I just clamped the cable with vise grips while soldering.
Anyway, it can be done and maybe you will find a way to make the wire tighter.
Post by: WT8095 on May 06, 2015, 09:09:10 AM
Check with your local jewelers - ones who make and repair jewelry, not a retail-only store. They will have the proper torch and brazing compounds, not to mention lots of experience.  ;)
If you have the right equipment and brazing paste, it's not any more difficult than common electrical or plumbing soldering. The principle is the same, just at a higher temperature.
Post by: David65coupe on July 30, 2022, 02:35:57 AM
I want to bring this back up. Is it O rings or bushings inside the handle? Can someone measure the pieces, then we may can get some made, just my thoughts.
David
Post by: Bossbill on July 30, 2022, 09:46:45 AM
As I recall it's a one piece step bushing.
The top one just slides out.
I think a 3D printed version would work.
(I really don't need another project right now.l)
