Author Topic: correct swaybar?  (Read 10872 times)
Offline hopeto
Re: correct swaybar?
« Reply #15 on: October 20, 2014, 08:54:34 PM »
Quote
FYI the 67/68 15/16 swaybar is different in contour compared to the 69/70 15/16 swaybar. This has been discussed before .
Would a 67 K Code Metuchen Coupe without Comp suspension have had the 15/16 or 7/8's bar?
Quote
The 15/16 largest bar also used a non typical end link kit different(at least for 67 ) then regular Mustang also.
What does that link kit look like/what's different?
Thanks!
Original one owner 84 GT Convertible with 1800 miles. 65 Silver Smoke Gray K Code GT Coupe - 65 Cyclone - 67 Vintage Burgundy K Code GT Coupe.  1970 Calypso Corral Boss 302 - 2012 Yellow Blaze Boss 302.
« Reply #16 on: October 20, 2014, 09:24:09 PM »
The MPC page from April 68 shows the application was the .958 for the 67 K code (not that it helps but C7ZZ-5482-D)
.............. The 15/16 largest bar also used a non typical end link kit different(at least for 67 ) then regular Mustang also.
Bob do you think that same link was used on the 67 competition suspension Mustang?  Never looked at that detail on a comp suspension 67 - missed an opportunity earlier this year I guess.
Have found two different head markings for the 67 Shelby end link bolts
« Last Edit: October 20, 2014, 09:33:02 PM by J_Speegle »
« Reply #17 on: October 20, 2014, 11:23:06 PM »
Would a 67 K Code Metuchen Coupe without Comp suspension have had the 15/16 or 7/8's bar?What does that link kit look like/what's different?
Thanks!
I am not 100% sure but think the K code only would have the larger sway bar if it had the competition suspension which also included ,AR or AM marked rear leafs ,adjustable shocks (like the Shelby) and high speed rated 15 inch wheels and tires. The 67 competition link kit used a longer fine thread bolt  and longer 68,69,70 style link tube but still mounted in the same way as other 65-67 Mustangs.
« Reply #18 on: October 20, 2014, 11:43:35 PM »
Jeff,I know you know most of this but for those reading , I have seen dozens and dozens of competition suspension unmolested 67 GT350/500 Shelby's with this detail and only one of maybe 4 competition suspension Mustangs with it . Partly because the competition suspension Mustang is rarer then the Shelby where it came standard. 3 of the 4 Mustangs I had checked on for this detail had been restored and had the short link.  The other 1 appeared to be unaltered and had the longer link. When you ordered a link kit for a 65-67 regardless of engine size etc. you get the short length if you order 68-70 you get the longer length regardless of engine etc. which may explain shorter variations on cars that should have the longer . That same situation however would not explain the longer style on a 67 if thought changed because it would require ordering the later year link kit . With these observations over the years the most logical conclusion to me is that the longer style was typical on Mustangs with competition suspension as they are on the 67 GT350/500 Shelby's.
« Reply #19 on: October 21, 2014, 11:50:44 AM »
Thought I would add that longer fine thread bolt needed for the longer tube end link was a 67 item (don't know if another application) because the 68-70 endlink of the same length which was standard for those years was a coarse thread . That fact helps identify if the end link has been replaced with a typical 68-70 Mustang version. FYI I had to prove my case  (a few years back) beyond a reasonable doubt with pictures etc. to a certain southern Indiana mal content  ::) who had insisted that the Shelby bar got the typical 65-67 Mustang short end link kit .-it didn't make a difference  :o    If you know the special one you understand why. ;D
« Reply #20 on: October 21, 2014, 11:53:37 AM »
Jeff , could you describe or show a picture of the two variations you have found?
« Reply #21 on: October 21, 2014, 10:03:47 PM »
Did it here since this started as a 68 Mustang sway bar discussion ;)
http://www.concoursmustang.com/forum/index.php?topic=9638.new#new
