Would expect them to reuse all of your parts or maybe (depending on builder) swap some out for already done (plated) individual parts. YOU can always ask to use only your parts. Some will automatically replace the fuel bypass which should not be a big issue.
Since you took pictures pay attention to the finishes of the arms and linkage - you will likely need to redo or recolor some of those. It always seems they plate the accelerator lever dichromate
Basically just about everything that can get plated (other than the carb body parts) get dichromated. Would expect that you will get the original carb tag back
Often I remove some or all (or ask them not to stamp) the inspectors, numbers and such - just do those myself when I receive it back
