Author Topic: ID this radiator - C7ZE  (Read 2367 times)
Offline rodster
« on: August 13, 2014, 10:55:48 PM »
Need help from the experts..   ;)
No markings on the top tank, C7ZE stamped on the side.
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline sportyworty
Re: ID this radiator - C7ZE
« Reply #1 on: August 14, 2014, 12:28:25 PM »
not an expert at anything but
That is a Modine big block 67 radiator as opposed to West Modine used on San Jose builds. Clean it up good to see if there is a suffix after the C7ZE as there are at least 6 different known ones. Perhaps farther down that same strap will be a smaller font date stamp. If there are no other stampings it may have had a brazed tag denoting application that has since come off. The bottom tank will tell you if it is an automatic or standard transmission application. It is not a Shelby being either Dearborn or Metuchen would likely be a an S or X code 390 application without air
« Last Edit: August 14, 2014, 12:31:33 PM by sportyworty »
Offline rodster
« Reply #2 on: August 14, 2014, 10:58:12 PM »
For not being an expert, you sure know a lot!  ;)  A lot more than me!
I would have expected a suffix after the C7ZE- but just can see one? I did find the date stamp. Not sure how to decode it.  It looks like V16M23 but will have to look closer since the stamping is very light.
I don't see any spot where there would have been a tag but will have to look again.
Wow, you are good.  It's out of a Dearborn 67 390 Auto w/o air!
So in your 'expert' opinion  ;)  could  this be the  original radiator for my car?
Thanks so much for the help! 8)
1984 SVO - 2A
Offline sportyworty
« Reply #3 on: August 15, 2014, 01:53:28 AM »
You are welcome.
When was your car built? We may have a match here ! Very cool
Offline rodster
« Reply #4 on: August 15, 2014, 11:20:20 AM »
02/07/67 one day ahead of schedule.
1984 SVO - 2A
Offline sportyworty
« Reply #5 on: August 15, 2014, 11:37:07 AM »
I would have expected a date format like 7AD (4th week Jan 1967) as commonly found on radiators. If the stamping on your rad represents Dec 23 1966 it would be a likely original match to your car and within the expected date range. That is an odd one but regardless of date is the correct radiator for your car. 8)
« Last Edit: August 15, 2014, 11:42:06 AM by sportyworty »
Offline rodster
« Reply #6 on: August 16, 2014, 12:15:58 AM »
Very cool!  8)  Thanks for the info.  I was expecting a different style date code too.
1984 SVO - 2A
