This is a thread originally posted on another forum.
Car is a early May 69 build AC, automatic, Jade Black, white interior, ex Hertz rent a car (yes Shelby/Ford sold these to Hertz after 66)
Enjoy
Just thought I would post these and may continue as the process continues.
Car - (mid spring) 69 GT350 being restored at the Resto-Mod Shop in Stockton CA (close by)
I'm babysitting the job so there is a learning curve on this first ground up attempt by this shop.
They shot the undercarriage with the first color last week (hard to get good pictures under the car right now)
Picture of the color used on the floor pans - This will get covered with body color (for this plant and time period)during a later step. Fairly typical dark gray batch color
Here the car is being masked off today as the seam sealer is being applied to the trunk and interior areas so that they can paint the interior and trunk areas - as soon as they get the texture right on the sealer.
Below are the dolly mark tools I built for this car... we'll see how they work.
Two pairs are for the blind holes and can be inserted and anchored from one end while the others bolt through the bottom to top to replicate what the factory did.
Did find that 69-70 Dearborn SOMETIMES used larger upper washers on the four through points than San Jose. Will post an article covering how to make these and how to use them.
[color:blue]Just though I would share[/color]
Are the pictures kind of small or is it just my monitor settings ? :shrug:
