Author Topic: 390 C6 Speedometer & heater cable routing  (Read 10958 times)
Re: 390 C6 Speedometer & heater cable routing
« Reply #45 on: April 11, 2018, 01:51:21 PM »
Like here?
YES! I saw it was further outboard from the crossmember bolt when I went home at lunch than I described, but yes, that's the correct hole!
« Last Edit: April 11, 2018, 01:54:43 PM by 67gtasanjose »
« Reply #46 on: May 25, 2018, 10:05:46 PM »
The unobtainium 377098-S does not show up in any Ford documents I have, other than the previously referenced assembly manual, whereas clip 379816-S32 shows up all over the place in MPCs and fastener manuals.
I've got a friend who is going to make a 3D image of 377098-S and look at having it reproduced.  He has a small business and makes a bunch of clips and other doodads for the Mopar world so has been down this road many times, successfully.
The design for the new part is done and he is getting quotes.  In the meanwhile I went junkyard picking with Bob (196667Bob) and picked up three used ones. Will create a for sale post for those that might need one.
1967 eight barrel
  • Guest
« Reply #47 on: May 28, 2018, 11:47:34 AM »
Angela, the clamp that holds the Ebrake cable to the inside of the frame rail retains the speedometer cable as well.
Offline TLea
« Reply #48 on: May 28, 2018, 08:18:39 PM »
Mine had a light rust patina over it, so I would guess bare steel also.
Finish is like brown anodized. Similar to anodized bronze
« Reply #49 on: May 28, 2018, 09:29:22 PM »
It is black chromate I believe. Process is just like the gold only black.
