Author Topic: 69 Dearborn Speedometer Cable Routing  (Read 4491 times)
Offline G Wood
« on: August 21, 2013, 10:47:11 AM »
Other posts I have reviewed helped me locate the firewall location for the bracket that holds the speedometer cable on a 4 speed car. I cannot find information or photos that show the location for the two clips that mount somewhere on the floor boards or transmission tunnel. Can someone assist.
65 Caspian Blue Fastback C Code, 11/4/64 SJ Build
70 Boss 302 9/29/69 Dearborn Build
12 Black GT500 SVT Convertible
Re: 69 Dearborn Speedometer Cable Routing
« Reply #1 on: August 21, 2013, 11:37:43 AM »
should be a hole on rh floorpan at end of tunnel area where it curves to firewall & nobody makes that clip holder correct so have to use old clip over.  Automatic car cable routes on lh side floorpan
Offline G Wood
« Reply #2 on: August 21, 2013, 02:36:13 PM »
Thanks, I have 2 clips on my cable so I assume there is another hole that I should be looking for? Do you roughly where the other is located?
Offline Brian Conway
« Reply #3 on: August 22, 2013, 04:56:15 PM »
     My car only has two attaching clips.  One at the lower engine compartment fire wall and the other that 'specialed' referenced.  I also have a drag pack reducer if that makes any difference.  Brian
« Last Edit: August 22, 2013, 05:53:54 PM by Brian Conway »
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
Offline G Wood
« Reply #4 on: August 22, 2013, 07:18:41 PM »
thanks very much, this answers my question.
Offline TLea
« Reply #5 on: August 27, 2013, 09:04:40 AM »
Thats not the original style clip. Usually one under prop valve also where cable exits firewall
« Reply #6 on: September 06, 2013, 01:24:57 PM »
[quote author=TLea
I don't think so.  Brian
San Diego, Ca.
Offline Wade429
« Reply #7 on: September 11, 2013, 03:49:31 PM »
Speedo cable routing. Pictures courtesy of  "DeadNutsOn"
« Last Edit: September 11, 2013, 03:52:17 PM by Wade429 »
