Author Topic: small rubber drain cover  (Read 1010 times)
Offline DEWilson
    • Maine Mustang Back from the Dead Restoration Shop
« on: July 04, 2019, 05:45:37 PM »
Hi   everyone   Trunk drop off drains (those small rubber drain valves on the inside facing the leaf springs  how where they install into square hole ?  sorry but never seen any in place they are all way rusted off
Re: small rubber drain cover
« Reply #1 on: July 04, 2019, 05:47:23 PM »
what year are you working on??? might be a good idea to put that into your signature otherwise you will get asked every time.
« Reply #2 on: July 04, 2019, 06:05:31 PM »
The drains on a 69-70 have two small "arms" or retainers designed into the drain that go into the square hole and are spread (like the fuel and brake line retainers with the "wings" to hold them into place. They can be challenging and require one had pressing the drain to the trunk drop while the arms/wings are spread. Some use a second person in the trunk to do the second part of the tasks or they can be spread by squeezing together the ends on the outside/under side of the car. Some may add a daub of hidden glue to keep them in place   ::)
Drain (slightly torn on the leading bottom edge) with the "wings" highlighted and both squeezed inward to one another after installation.
69 Dearborn and San Jose examples
« Last Edit: July 04, 2019, 06:16:37 PM by J_Speegle »
Offline DEWilson
« Reply #3 on: July 05, 2019, 11:10:41 AM »
 thank you Jeff
Offline 7Lscjracer
« Reply #4 on: July 06, 2019, 02:10:45 AM »
https://www.deadnutson.com/trunk-drain-rubber-curved-c8zb-65-11202-a-san-jose/
Here's a repro on Jack's site.
I'd never noticed or heard of the supplier differences in this part depending on the where the car was built before I saw this catalog listing.
I've seen one of them NOS, but no idea which version it was.
Hard enough to find two, but now there are versions that have to be matched up too. >:(
Bought May '81, sold Sept '20
« Reply #5 on: July 06, 2019, 02:34:06 AM »
Thought about mentioning but since he is building a NJ 69 choose not to. But your posting will bring the subject to light - not sure if all San Jose cars received them but would not question them if I saw a pair on a San Jose car. Just need to check that one extra detail on unrestored cars in the future. Don't show up well in pictures
Nice to see them reproduced, available and done so well
« Reply #6 on: July 06, 2019, 12:56:24 PM »
Special Ed (Ed Meyer) did the research on this one I believe. He also provided samples to use so it could be made available. Atta boy Spec Ed.
