Author Topic: 70- Luggage protection stud covers  (Read 1530 times)
Offline 1970 Snake
« on: March 24, 2018, 03:04:07 PM »
Can someone advise as to which studs the luggage protection covers go on the tail light buckets of my 1970 Mach 1. The AMK attachment kit only comes with 2 not 4 or 8.
I am guessing it would be the top inner studs the ones closest to the trunk latch as they are the most exposed to catch on some luggage.
« Last Edit: March 28, 2018, 12:10:11 AM by J_Speegle »
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Online specialed
Re: Luggage protection stud covers
« Reply #1 on: March 25, 2018, 09:45:04 PM »
correct stud but they are black rubber & small screw tip just below it is the small black plastic protector from what i see on dearborn anyway
Offline 1970 Snake
« Reply #2 on: March 26, 2018, 02:02:43 AM »
Thanks for the update, does anyone make the black protectors for the large and small screw tip??
Re: 70 Luggage protection stud covers
« Reply #3 on: March 28, 2018, 12:03:26 AM »
Been gone for a couple of days.
Guess you didn't see this when you did your search
http://www.concoursmustang.com/forum/index.php?topic=2824.msg15073#msg15073
Since you didn't specify when or where your car was built the following is only a general overview of the subject
There are four different luggage protectors types and locations for you car
1- Rear marker light stud covers/protectors. Looks like 67 talllight studs are similar and could be made to work
2- Taillight mounting stud covers/protectors .  NPD had some (listed for a different application) They look similar to the screw protectors (with the small little release from the mold nipple at the end) yet more like rubber than the hard material used for the voltage regulator screw covers for 65-6
3- Taillight screw covers/protectors - These appear to be one and the same as the interior screw covers. Don't know anyone making them currently
4- Interior screw covers/protectors
5- Drivers side wheel house pinch weld strip cover/luggage protector
Two versions - with Calif evap system
And without
Of course if you have a factory rear spoiler/wing there are more ;)
« Last Edit: March 28, 2018, 12:13:48 AM by J_Speegle »
Offline 1970 Snake
Re: 70- Luggage protection stud covers
« Reply #4 on: March 28, 2018, 11:36:26 AM »
Prefect Jeff, thanks for the pictures, I am still trying to source the grey wheel tub pinch weld cover, have a black one but Dearborn had grey ones.
Online specialed
« Reply #5 on: March 28, 2018, 01:00:11 PM »
we been selling the original grey ones on ebay for years  fastbacks are shorter than coupe convertible
