Author Topic: 1965 / 1966 V8 Radiators - Including Solidered Tags  (Read 18481 times)
65Autolite
  • Guest
« on: September 11, 2016, 11:27:42 PM »
Moving to spreadsheet
« Last Edit: May 25, 2020, 05:47:53 PM by J_Speegle »
Re: 1965 / 1966 V8 Radiators - Including Solidered Tags
« Reply #1 on: September 12, 2016, 12:47:22 AM »
There were two style radiators used in 1965 / 1966 Mustang production.
We'll we all have to start somewhere and so you'll have at least one response to your post  ;)
Let me start with - Which one of the two styles does the factory installed "Desert cooler" fall into?
Offline MattDoscher
« Reply #2 on: September 12, 2016, 02:35:14 PM »
What about the 6cyl folks?  I know this topic was started initially for the V-8 crowd.  Is there any info on 6cyl rads?
Matt
Matt Doscher
5H25T582252
Offline Josep
« Reply #3 on: September 12, 2016, 03:32:36 PM »
Matt
Well, I'm afraid I started a thread regarding tags on rads, and my car is a 6Cyl..!
So Autolite started another thread..
Josep
Offline jstefanick
    • Restoration Pics
« Reply #4 on: September 12, 2016, 03:34:42 PM »
Autolite-
I can see your passion in wanting to get the details right- I think that is why we are all here, and I applaud you for trying to get an accurate baseline.
While I am not an expert at all myself, I believe I am well read and have access to most of the same internet sources most have for info, for better or worse.
For your initial post in this thread, it is very detailed to the point that I am curious of the source of your info? I cannot say I have any doubt, as I cannot add anymore beyond the in depth searches I do on the Internet.
Do you have some inside info, or perhaps know someone that has this store of information that we are all missing?
Good job trying to clarify what these tags mean and the effort is appreciated.
Offline 1970shelbyguy
Re: 1965 / 1966 Radiators - Including Solidered Tags
« Reply #5 on: September 12, 2016, 05:34:41 PM »
thought i'd ask about the radiator shroud.  when did they come factory installed. i was told at a show sunday that the shroud was an option-  owner's  car was an early production 65 C code fastback - no a/c.   thanks   hey jeff saw your video hanging out in the cougar wrecking yard  describing date codes -  wow!  great stuff
1970 gt500  grabber blue  june/69     1970  boss 302  metuchen  dec/69
« Reply #6 on: September 12, 2016, 05:44:42 PM »
in 65-66 only k-codes & cars with a/c had a shroud from the factory.
« Reply #7 on: September 12, 2016, 06:23:34 PM »
 well  very good! - thanks for the verification-
« Reply #8 on: September 13, 2016, 07:05:51 PM »
Sources added above.
Good job on the radiator information.
« Reply #9 on: September 13, 2016, 08:13:07 PM »
Looked through my collection of pictures and can only offer the following to add to your research. Most I could not read the stamps and many (T code cars) had the no strap style of radiators.
C4ZE-D2 -  (12-64) Automatic only
C6ZE-D2 - (5-66) Automatic only
Thought you might be interested in the following
C4ZE-B2  (6-64)  Very very early -Possible first couple of days of production - F code - Automatic, non- AC
Hope this helps in some way
« Last Edit: September 14, 2016, 12:38:47 AM by J_Speegle »
Offline larryharvey
Re: 1965 / 1966 Radiators - Including Soldered Tags
« Reply #10 on: September 17, 2016, 09:55:07 PM »
Autolite,
Don't want to hijack your thread, but need groups opinion about this radiator. I uncovered it with the rest of my Hi Po parts. Has a couple of tags that I believe are radiator repair shop tags. They used them years ago to id customers radiators. Also wantwant some feed back on weather this radiator would be appropriate for an April 65 Hi Po.
65 April 13th Dearborn K code GT
« Reply #11 on: September 17, 2016, 10:07:53 PM »
Autolite,
Looks like a long shot for a Deaborn or NJ  April built car just looking at the date alone. SHould be able to confirm the typical date spread from other original examples but think almost a year before is a long time
Offline larryharvey
« Reply #12 on: September 17, 2016, 10:33:48 PM »
Thanks Jeff,
That's what I was thinking also. I may just get it re-cored anyway. I have just about given up on finding the correct date coded radiator.
Thanks again
Larry
Offline sgl66
« Reply #13 on: September 18, 2016, 12:43:49 AM »
Autolite,
Does your G1 have 12 fins per inch? I found this chart which I believe explains the difference between G1 and Y1 radiators.
Offline larryharvey
« Reply #14 on: September 18, 2016, 12:55:55 PM »
AUTOLITE,
I will check it out tomorrow and post.
