Author Topic: WTB: WANTED: 65-67 Vinyl Top Retainer Strips C5ZB-6553728-A  (Read 2119 times)
« on: April 16, 2016, 09:47:33 AM »
These strips were riveted down (9 rivets used each side) within the drip rail on factory installed vinyl roof cars. The strip runs the full length of the drip rails.
Any leads would be great. These might need to be from a "dry climate" area so if you are scouting for parts, please keep me in mind.
They can be carefully coiled for shipping purposes ;)
Thanks.
« Last Edit: April 16, 2016, 09:54:35 AM by 67gtasanjose »
Offline preaction
Re: WTB: WANTED: 65-67 Vinyl Top Retainer Strips C5ZB-6553728-A
« Reply #1 on: April 16, 2016, 04:18:31 PM »
I have a vinyl roof car too and was told early cars came with stainless steel parts and later they switched to aluminum.
« Reply #2 on: April 16, 2016, 04:58:12 PM »
Hmm...Is this on your 68? If so, I doubt  you have 9 rivet holes each side in the drip rail, like the 67-down.
Offline preaction
« Reply #3 on: April 17, 2016, 02:15:36 PM »
It seems I spoke to soon, the information I have for this is for a 67 cougar clearly a little different.
Offline C5ZZ
« Reply #4 on: April 23, 2016, 08:33:41 AM »
One of the yards I go to has a 66 coupe with a vinyl top, the car is very rusty from living
here in the rust belt. Leave me a pm if all else fails and I can check into it for you.
MCA # 00945
Rangoon Red/Red Interior
« Reply #5 on: May 03, 2016, 08:06:27 AM »
I have a few members following leads on locating these. Thanks guys, & let me know if you've had any success. This morning, while searching WCCC site for vinyl material for my roof, I found this:
http://www2.cougarpartscatalog.com/67vinylkeeper.html?attribs=77
A good read that explains the running change on Cougars for this stripping (early & late)
NOTICE THE ENGINEERING NUMBERS [and change-over dates] THAT ARE CITED :)
*possible there is a "typo error" on WCCC site citing "C5ZB-6353728-A" This would not seem like it could be a viable engineering number IMHO. I believe the correction might be a "5" instead of a "3". (body code "65" part of a Mustang engineering numbering system)
« Last Edit: May 03, 2016, 08:15:36 AM by 67gtasanjose »
« Reply #6 on: May 03, 2016, 02:46:51 PM »
Many of the listings with part numbers on our catalog are from before Scott.
Cougars have longer roof lines so those retainers would be longer than for a Mustang.
« Reply #7 on: May 03, 2016, 04:04:16 PM »
Kind of what I thought too (Cougar is longer) but I would almost have to wonder if these vinyl top strips were potentially used on various carlines, possibly cut to fit?
Looked to me that the number I referenced at the WCCC site didn't follow the decipher guideline for Ford parts since a Fastback likely didn't ever need a vinyl roof. (it was "cool" enough without it ;) )
« Last Edit: May 03, 2016, 04:36:22 PM by 67gtasanjose »
